Dyna Coil installation
  • waterman
  • waterman's Avatar Topic Author
31 Oct 2005 12:03
#5652
Anyone have any pictures of a Dyna coil installation? Was it hard? Since I've read that Accel coils can be installed using the same mounts as the OEM parts, what do I have to do for the Dyna's (since I just got them and so its too late for the Accels)?
  • cudaosix
  • cudaosix's Avatar
Re: Dyna Coil installation
31 Oct 2005 12:39
#5659
The installation on my bike was easy. I put in 3ohm Dynas a few months ago. I over analyzed and researched The coils and install like I do with everything. And it turned out to be simple. I bugged Wiredgeorge and Jeff asking questions (by the way, thanks again for the help guys) and traded e-mail with someone at Dynatech till I had enough info to keep me satisfied. They mount with the same hardwear your factory coils use, you just need to have the towers facing forward. I had a resistor to bypass, dont know if yours is the same set up, but that was basicly it, ran some new primary wire. If you do a search for Dyna Coils in the archives you'll find a ton of threads with helpfull info and pics.
  • waterman
31 Oct 2005 12:47
#5660
Resistor to bypass? I'll have to do some research on that. Over analysis is not a bad thing. Don't sell it short (I'm still curious about the damage that I may have done by not grounding my plug wires when I checked my compression).
  • ltdrider
  • ltdrider's Avatar
31 Oct 2005 15:00
#5691
Here is a picture of my Dyna Coil Installation.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • ltdrider
  • ltdrider's Avatar
31 Oct 2005 15:02
#5692
Let's try again...First Picture:
Greensboro, NC
  • ltdrider
  • ltdrider's Avatar
31 Oct 2005 15:02
#5693
Next Picture:
Greensboro, NC
  • ltdrider
  • ltdrider's Avatar
31 Oct 2005 15:03
#5694
Next:
Greensboro, NC
  • ltdrider
  • ltdrider's Avatar
31 Oct 2005 15:03
#5695
And finally:
Greensboro, NC
  • donthekawguy
  • donthekawguy's Avatar
31 Oct 2005 15:31
#5703
Accel coils are a pain in the a## to put in. You have to make the mounts yourself. Go with the Dyna's.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Grovercan
  • Grovercan's Avatar
31 Oct 2005 15:48
#5711
Here is an additional pic from my install. I was a little paranoid with the aluminum spacer that sits right in front of the bottom terminal. So I made a plastic one so there is no risk of an arc happening under the fuel tank.
Grovercan
Post edited by: grovercan, at: 2005/10/31 18:51
  • Grovercan
31 Oct 2005 15:52
#5716
Lets try the picture thing again!
Post edited by: grovercan, at: 2005/10/31 18:53
  • waterman
01 Nov 2005 05:17
#5848
Thanks to all of you. These pictures will be real helpful. At least, I can see how it needs to be doen. Dyna coils sitting in the box look a little intimidating.
