Timing issue
- veloman
Timing issue
22 Dec 2012 11:15
I have just finished rebuilding my z500, engine runs very well
but when I connected a strobe I found 1-4 were ok but 2-3 were to advanced
to move the back plate would ajust 2-3 but move 1-4 out
Is there a way to rectify this problem
thanks
thanks
Re: Timing issue
22 Dec 2012 14:23 - 22 Dec 2012 14:29
Assuming these are new points - it sounds like one set or the other may not be gapped exactly right. Use a dwell meter to precisely set the gap on both sets of points, then set the timing again. If they are not new points you should replace them and don't forget to lube the felt wick. Ed
Last edit: 22 Dec 2012 14:29 by 650ed.
- veloman
