Head Light Switch
- BIGKEVIN
Re: Not Starting
23 Dec 2012 02:58
I also noticed the when the key is turned on, the oil light does not come on anymore and neither does the high beam indicator.
1976 KZ900
2006 ZX6R
2006 ZX6R
- Humenik
Re: Not Starting
23 Dec 2012 20:09
I had a similar problem on my 76, turns out
I had a pinched wire in the right hand control
( starter headlight run stop) and had just
moved it a little and kept blowing the fuse.
Garry
Garry
1976 KZ900 LTD
1984 Honda VF750 F Interceptor
Toronto, Ontario
Toronto, Ontario
- Humenik
Re: Not Starting
23 Dec 2012 20:13
Possibly a loose connection further along
the harness near headlight. A pulled wire
my not have loosened under the tank but
further along.
garry
further along.
garry
1976 KZ900 LTD
Toronto, Ontario
Toronto, Ontario
- BIGKEVIN
Re: Not Starting
23 Dec 2012 21:23
I will continue to look. Will check the right side handle bar and inside the head light assembly.
1976 KZ900
2006 ZX6R
2006 ZX6R
- BIGKEVIN
Re: Not Starting
25 Dec 2012 20:38
I got my head light issue resolved today. I checked the voltage at the fuses and I was seeing voltage going into one of the fuses on the blue wire, but not any on the other side of the fuse. Pulled the fues and it did not look like it was blown. Tested the fuse with a multimeter and it checked good. Put another fuse in anyway and the light come on when the key was turned on. Thanks for all of those who helped with this issue.
1976 KZ900
2006 ZX6R
2006 ZX6R
