the key inside my starter keeps breaking
- KZ_900_Z1
04 Dec 2012 15:05
my starter key keeps breaking in my 1976 kz900z1. i have spent over 2,000 dollars in trying to fix it but that key never lasts longer than a month i have replaced the key 5 times and the starter twice, so what do i do?
1976 kawasaki kz900
Re: the key inside my starter keeps breaking
04 Dec 2012 16:16Hello, Z_900_Z1, and WELCOME to KZrider!KZ_900_Z1 wrote: my starter key keeps breaking in my 1976 kz900z1. i have spent over 2,000 dollars in trying to fix it but that key never lasts longer than a month i have replaced the key 5 times and the starter twice, so what do i do?
Until better advice comes along, here's an excerpt from the FSM.
- StreetfighterKz
04 Dec 2012 16:36
I've heard of people lapping the crank nose and then applying red loctite. Some of the high compression, big-bore push button dragbikes are done like this.
I think Mark has similar issues on his bike.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
04 Dec 2012 17:35Did this issue already exist when the bike was acquired?KZ_900_Z1 wrote: my starter key keeps breaking in my 1976 kz900z1. i have spent over 2,000 dollars in trying to fix it but that key never lasts longer than a month i have replaced the key 5 times and the starter twice, so what do i do?
Or was everything okay until the issue unexpectedly occurred?
What repairs have been attempted, other than replacing the key?
Is the keyway in good condition, or wallowed out?
What other parts have been replaced underneath the alternator cover?
Does the same shop keep supposedly repairing it over and over, and how do they diagnose the issue?
04 Dec 2012 17:55
The correct WOODRUFF KEY Part No. 92038-001 should be available at any Kawasaki dealership.
And is also listed at Z1E
Click > www.z1enterprises.com/ListItems.aspx?keywords=92038-001
- roy-b-boy-b
05 Dec 2012 09:12
I would imagine the thicker rubber piece would cause the woodruff to shear.
- Motor Head
05 Dec 2012 11:15
If the rubber dampener is to thick, the starter clutch gear won't freewheel. That would be your first clue its to thick. It would sound like the starter staying engaged, as it would be.
- roy-b-boy-b
05 Dec 2012 14:13
The procedure for correct fit is to use a piece of clay and place it behind the flywheel/stator magnet and tighten the parts down to specs and then remove the parts and measure the thickness of the clay.
Just trying to help out without digging out the manual.
After working on the newer design 1000 engines I found this procedure to be a pain on the 900 engines. Roy
- sflaz1
05 Dec 2012 16:36
What does the tappered portion of the crankshaft look like? Is it scored from the rotor spinning on it? I had a similar problem and used some emery cloth to smooth the crank and put red lock tight on the shaft. It has worked so far.
Bought my 1973 Z1 in late 1978. Turbo charged 1982.
- mark1122
- Keep twisting it
06 Dec 2012 15:43
BINGO.
this is actually more common than u may think. i believe that is why Ma kawi changed the crank design in 77.
the 73 to 76's had a small 6mm (18ftlbs.)bolt holding the stator on and the woodriff key. the 77 on up use a large bolt that torques on at 105 ft lbs. even some of the j models had problems.
the key can sheer and when the stator spins on the crank, it can damage the matting surfaces. if the mating surfaces of the crank and stator r not near perfect, they will NEVER LOCK together as they should. u can try to repair it by using lapping compound, but i have never been successful with it. the only way i have over come a scored crank, is to have the crank end changed or replace the crank. also replace the stator if it has any scoring, u dont want to ruin another crank.
Hope this helps.
Hope this helps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- jarrad
07 Dec 2012 01:56
the only time i have ever had e a woodruff key sheer off is when it was not torqued up correctlly...
"IF EVERYONE HAS ONE, I DONT WANT ONE"
79 z1000st BUILD:
www.streetfighters.com.au/for...-OLDSKOOL-quot
R6 build:
www.customfighters.com/forums...ad.php?t=53108
KDX build:
www.dirtrider.net/forums3/sho...d.php?t=166143
79 z1000st BUILD:
R6 build:
KDX build:
- donthaveakawman
07 Dec 2012 02:44
I wonder if there is a recall on those, mine seems to make a grinding noise after sitting for a little while when I restart the engine.
