the key inside my starter keeps breaking
- 750steve
Re: the key inside my starter keeps breaking
08 Dec 2012 10:10 - 08 Dec 2012 10:15
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 08 Dec 2012 10:15 by 750steve.
- wireman
08 Dec 2012 11:57Try cranking over a 13:1 z1 motor with electric starter and it come back against itself! :woohoo:jarrad wrote: the only time i have ever had e a woodruff key sheer off is when it was not torqued up correctlly...
- KZ_900_Z1
28 Jan 2013 07:48
okay guys well the 900 is running great a couple of kinks I need to work out some kinks before I start my custimization but I have a new problem I fixed my starter problem but the smaller gear held in with some sort of holding pen isnt holding the gear in place so it can spin once the starter is engaged to fire the bike up I feel like it may be too short cause it doesnt want to stay put so I cant even get the case back on without that gear sliding forward allowing my starter to freely spin so im stuck with kick starting till someone can tell me how to fix this
1976 kawasaki kz900
- turboking
28 Jan 2013 21:11
I've always lapped with fine clover valve grinding compound and GREEN loctite...... works for big cc turbo and nitrous engines
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- KZ_900_Z1
28 Jan 2013 21:17
and that will hold in the crank pin? if so I will do that
1976 kawasaki kz900
- pig9r
29 Jan 2013 01:57 - 29 Jan 2013 02:00okay guys well the 900 is running great a couple of kinks I need to work out some kinks before I start my custimization but I have a new problem I fixed my starter problem but the smaller gear held in with some sort of holding pen isnt holding the gear in place so it can spin once the starter is engaged to fire the bike up I feel like it may be too short cause it doesnt want to stay put so I cant even get the case back on without that gear sliding forward allowing my starter to freely spin so im stuck with kick starting till someone can tell me how to fix this
If you are talking about the starter gear dowel there is a recessed area on the inside of the cover that keeps it from coming out. If it won't stay put until you put the cover on pack it with some grease to hold it.
Last edit: 29 Jan 2013 02:00 by pig9r.
- KZ_900_Z1
29 Jan 2013 03:23
my problem is, is the gear slides forward and wont stay in alignment is just slides forward what could be the problem?
1976 kawasaki kz900
- donthaveakawman
29 Jan 2013 04:43
no wonder, it goes in the ignition.
