1976 kz900 battery draining
- kzkrazy07
27 Nov 2012 22:09
i have a new gel battery. bike starts up fine when battery is fully charged and runs fine. just rode the bike today after sitting a few wekks from last time i took it out when the battery was charged and after traveling a few miles stopped to pour gas turned ignition on got green neutral light dim and turned over a few times and didint want to start. not enough juice to crank. kick starts right up. traveled another 5 miles stopped and when i was leaving same thing not enough juice to start. something is draining my battery or its not charging the battery. not sure if it could be bad rectifier or bad stator? any suggestions on how i can figure out what is the problem? thanks
Re: 1976 kz900 battery draining
27 Nov 2012 22:32 - 27 Nov 2012 22:33Hello, kzkrazy07, and WELCOME to KZrider!kzkrazy07 wrote: i have a new gel battery. bike starts up fine when battery is fully charged and runs fine. just rode the bike today after sitting a few wekks from last time i took it out when the battery was charged and after traveling a few miles stopped to pour gas turned ignition on got green neutral light dim and turned over a few times and didint want to start. not enough juice to crank. kick starts right up. traveled another 5 miles stopped and when i was leaving same thing not enough juice to start. something is draining my battery or its not charging the battery. not sure if it could be bad rectifier or bad stator? any suggestions on how i can figure out what is the problem? thanks
Would disconnect the battery and charge it overnight at 2 amps maximum.
Battery should be fully charged when performing a basic test of the charging system.
After reinstalling the battery and starting the engine, measure the voltage between the battery posts at idle rpm, looking for 13~14 volts.
Measure the voltage between the battery posts at 4,000 rpm, looking for 14~15 volts.
Too low voltage could indicate a faulty rectifier or faulty alternator or an issue with the associated wiring or connectors.
Too high voltage could indicate a faulty regulator or an issue with the associated wiring or connectors.
If needed, Z1 Enterprises lists a combination rectifier-regulator which performs well.
Last edit: 27 Nov 2012 22:33 by Patton.
- MFolks
27 Nov 2012 22:53
Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s ,GPz1100’s
And possibly the 750’s).
To check to see if the alternator is working you need to follow these simple steps:
1. Fully charge the battery as this will be the power source during this test.
2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it.
3. Start the engine and let it warm to operating temperature.
4. If you're worried about overheating, position a large fan for cooling the engine.
5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector.
6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3, 2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!! The Alternator produces a three(3) phase A.C. power that is changed to D.C. by the regulator/rectifier, powering the motorcycles electrical system.
7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced. Some of the older Z1’s and KZ900’s were reported to be phase sensitive, so check the wire colors carefully.
8. Using an OHMETER, Check the three wire combinations again, looking for a reading of 0.36 - 0.54 OHMS. If the readings are above or below, the stator may be bad and need replacement. Also check from any of the three YELLOW wires to ground, this will show if arcing took place. Check only with the engine off !!
9. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty. Inspect the wiring for signs of shorting or overheating too. www.z1enterprises.com sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while.
10. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short(I.E. twisted together with insulation damage).
11. The sprocket cover will have to be removed to access the electrical connectors coming from the alternator, the left foot peg assembly and shifting lever will have to come off also.
Alternator Stator Replacement On the Older 4’s
Source for replacement Stators
A. www.electrosport.com/technical-resources.../fault-finding-guide
B. www.customrewind.com
C. www.rmstator.com
D. www.regulatorrectifier.com
E. www.oregonmotorcycleparts.com (Rectifier/ Regulators Only)
1. If by testing either by checking the output voltage from the stator or by using and ohmmeter for resistance and the stator is determined to be bad, replacing the stator is not a difficult job.
2. The motorcycle owner should have on hand a replacement alternator gasket as it will tear on removal and leak if reused.
3. Put the bike on the center stand if possible and lean it to the right to minimize the oil volume that could come out when the alternator cover is removed.
4. Have selection of Metric wrenches and sockets along with Metric Allen keys to be able to accomplish this repair. ¼" and 3/8" ratchets and extensions may be needed along with Allen bits.
5. Remove the gear shift lever, the sprocket cover and possibly the left foot peg assembly.
6. A catch pan for what little oil will be lost should be positioned under the alternator on the left side. Newspapers will soak up any oil lost or some kitty litter will do as an absorbent.
7. Remove the alternator cover fasteners, some bikes use a socket head cap screw(Allen type) and others use the Phillips head type, the #3 screwdriver bit fits best for those. Use a small dish or can to collect the removed fasteners from the parts to prevent loss/damage.
8. The alternator stator is secured to the inside of the cover usually with three Allen headed bolts, Some bikes may have Torx style fasteners(looks like a star), Remove them and disconnect the three yellow wires that have bullet connectors on them from the bundled wires inside the sprocket cover.
9. If your bike has some color other than yellow for the alternator output wires, make note of what goes where as the older Kawasaki’s were phase sensitive in regard to the regulator/rectifiers.
10. When installing the replacement stator, clock or position the output wires and grommet so they fit into the small port under the alternator cover without being pinched or damaged.
11. Tighten the three Allen or Torx fasteners, securing the replacement stator to the cover. I like using the BLUE Loctite # 242 for hardware that can be removed with hand tools.
12. Remove the old gasket from the mating surfaces of the alternator cover and engine case by scraping with a piece of sharpened plastic like Lexan or Plexi-glass as these will not gouge the soft Aluminum Cases. Avoid using a metal gasket scraper for this.
13. Position the alternator cover, checking for pinched wiring and install the fasteners with a little silver anti-seize on the threads, tightening to the correct torque.
14. Connect up the output wires to the mating female bullet connectors and while you’re in there, check the routing of the wire bundle that runs through there.
15. Inspect for signs of heat damage to the wire insulation and vibration damage too.
16. The side stand switch, neutral switch, and oil pressure switch wiring are all bundled with the alternator output wiring running above and behind the engine output sprocket. This bundle runs in a channel as it goes up toward the various electrical connections.
17. The regulator/rectifier plug on the 80’s bikes usually has six wires in it:
A. One (1) WHITE with RED stripe, this is the bikes main power wire usually 12 gauge in size.
B. One(1) smaller BROWN wire, probably 18 gauge or so, the voltage sense wire for the regulator/rectifier, helps keeping it from overcharging the battery.
C. One(1) BLACK with YELLOW stripe wire, part of the ground circuits, maybe 16 gauge in size.
D. Three(3) YELLOW wires, maybe 14 gauge in size, the alternator output wires going to the regulator/rectifier which converts the Alternating Current(A.C.) to Direct Current(D.C.) using rectification, producing the power to run the motorcycle and charge the battery.
18. Reinstall the sprocket cover, again checking for pinched wires before tightening. Install the shifter on it’s splined shaft checking for proper location, and the left side foot peg assembly.
19. Except for the minor oil spill and reluctant fasteners, it’s not a very difficult job to do.
A video on testing and troubleshooting a motorcycles charging system:
C. www.rmstator.com
