Battery draining too fast?
- X_Saint
26 Nov 2012 22:06
I just bought an 82 kz750 ltd and I'm curious on the battery. It was having trouble starting the other day and I was trying to start it for about 5 minutes maximum before it wouldn't make anymore noise to start because the battery was dead. I had to charge it back up before i could try to start it again. Is this normal for a full battery to drain that quick while trying to start my bike? I have it hooked up to a battery tender as of now for the winter. I checked the water inside and it looks high enough. I'm new on batteries so i wanted to make sure what was going on before I go and buy a new one for nothing. Thanks, Dylan.
Re: Battery draining too fast?
26 Nov 2012 22:39
Would remove battery, add distilled water as might be needed to bring levels within specs, charge overnight at 2 amps maximum, and then have the battery load-tested at Auto-Zone, Walmart, or other auto parts dealer.
The following user(s) said Thank You: X_Saint
- MFolks
26 Nov 2012 23:26
You'd be very lucky to get 5 years out of a motorcycle battery, they live in an environment of vibration,heat, and imperfect charging systems. If it were me, I'd have it load tested at least once a year.
- ramtough_63
26 Nov 2012 23:37
I Have ha da bad batteries that were brand new a load teszt is the real way yo find out if its time for a new one. Bttery with a bad cell will mimic all kinds of ingnition related problems
will be my first test nech Quote Cahrging problem I Have
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- X_Saint
26 Nov 2012 23:42
I appreciate it guys. Gonna have it load tested this week, thanks a bunch.
- angryeric116
12 Dec 2012 15:06
Are you sure your bike is charging the battery?
charge the battery then, take a voltage reading with a multimeter
with the bike running, take another voltage reading.
If it is the same for both readings with the voltage dropping, you may have a bad regulator rectifier or stator coil.
If the reading is higher and fluctuating with the bike running, then you most likely have a bad battery.
1979 KZ 1000 LTD B3
in the process of restoring.
Weisco 1 to 10.25 pistons
unknown 4 into 1 , pod filters, #122.5 main jets, #15? Idle jets
