Stumped! Wiring Issue 82 KZ750 csr..
- tjgonz
27 Oct 2012 00:25
Hi I recently tore down my kz & labeled all wiring.
Well finally finished her & went to wire her up this morning..failed horribly.
First off I basically have two connections that seem to have no place & can go together but I have them labeled differently. No match for either wire & I ran them together just to double check & they started smoking & regulator heated up pretty good. One wire is off of the stator I believe, it is black & yellow & comes off the clip of a braided bundle from the side cover near the chain with two other yellow wires. The other is black & yellow and is just somewhere in the middle of the harness. Without these connected I got lights & key ignition working but my starter just clicked when push start button was pressed. Couldnt find a diagram for my exact bike. Any help please before I go crazy here. Thanks guys!
- nobody
Re: Stumped! Wiring Issue 82 KZ750 csr..
27 Oct 2012 00:35 - 27 Oct 2012 00:39
Black and yellow is ground.
There's a wiring diagram in KZrider's FILEBASE (top of screen).
Click > www.kzrider.com/filebase/doc_download/36...z750m1wiringdiag0002
Last edit: 27 Oct 2012 00:39 by Patton.
- tjgonz
27 Oct 2012 00:37 - 27 Oct 2012 00:38
Found a close diagram in the database for the M1.
Yes Ive swapped between two full charged batt & one of the wires is hot! lol
Last edit: 27 Oct 2012 00:38 by tjgonz.
- Motor Head
27 Oct 2012 10:07
If you are still having issues, wires not connected properly, post up some decent photos of the wire etc.
Also if your wires got hot, and the R/R started to smoke, it is probably shot. The wires also may need to be replaced/ repaired. When they get hot, the insulation gets compromised, causing shorts to other wires or ground.
- tjgonz
31 Oct 2012 05:52
Thanks for the help guys..Im so frustrated.
Ive figured out my problems are ground wires.
Does anyone know if I need a ground wire to the frame or does ground from engint to battery ground everything? Wiring is not my specialty but may need to redo my harness myself because a shop is just not an option. Thanks!
- MFolks
31 Oct 2012 14:25
The battery is normally connected from the Negative(-) terminal to an engine mounting bolt. It should be at least 8 AWG (American Wire Gauge) in size. If the cable is too small, the Negative power will attempt to use any other ground wires to return to the battery, making the wires smoke, and making you think of an electrical short.
The Positive(+) terminal on the battery usually goes to the starter solenoid, using one of the terminals as a common point for power distribution. Again, it will be about 8 AWG in size. From the starter solenoid,another cable will go to the starter motor, providing current to make it work, when you push the start button on the right handlebar switch.
- MFolks
31 Oct 2012 14:29
All battery cables must be clean and tight for maximum current flow, and the other Black with Yellow striped wires must have a good ground connection. If the various grounding places on the frame are corroded or rust filled, an M6 X 1 tap should be able to remove the rust for improved ground connection.
- tjgonz
01 Nov 2012 22:40
Thanks MFolks, great advice. I found out I had some connections reversed on my electronics. I did get my lights all working & my starter solenoid clicks but nothing more, appears to be no spark on kickstart..
Now I still have the blk/ylw ground from voltage reg clip with no home. When I ground it to the female blk/ylw ground it shorts. So I assume my regulator is not grounded, bike wont start, correct? BTW I have no grounds on my frame, only negative battery to engine case.
- Motor Head
01 Nov 2012 22:49
Go back to the wiring diagram Patton posted, and look at this
This shows where your Ground wire should be bolted to the frame.
- tjgonz
01 Nov 2012 22:58
Sweet! I wasnt too sure, my bike has no side covers or anything like that pretty much is bare minimal, wish I took notes of where it was grounded. So I think my next step will be opening the harness & checking the ground then bolting to frame somewhere. Thanks again Motor Head!
- tjgonz
01 Nov 2012 23:08
Wire circled off the reg clip is my problem.
The ground in your pick looks like it doesnt go the that ground[top arrow].
Man I just want this to be done with lol. :woohoo:
