Hot fuse problem.
- built408
Re: Hot fuse problem.
19 Oct 2012 12:33
Ya the issue at hand is a hot fuse. I don't think my meter is bad as it's new this is literally the first time it's been used. I'll do the battery test when I get home. So do you think I should just replace the fuse box first with the blade style to see if that fixes my problem?
1978 KZ1000 A2A with MKII body you know you like it
- Del_Herring
19 Oct 2012 13:16
I respectfully disagree with Ron. Running too much voltage through a fuse can cause it to get hot. If the voltage is higher than it should be, current's going to increase, and it'll get hot. That's how fuses work, when they get too hot they pop, whether or not 17 volts is enough of an overage to cause a notable increase in heat, I'm less sure, but it's a problem that should be corrected either way.
I'd start with the reg/rec, because you need to do it anyways. Then if the hot fuse issue persists, I'd start considering swapping the box. Do check the clips on it like Ron says though, bad connections there can cause it to heat up.
1983 KZ750-N2 Spectre
- built408
19 Oct 2012 16:35
Thanks for all the help. I think I will do both. The strange thing is the fuse gets hot with the ENGINE OFF. When I turn the key on its fine but when I switch on the head light on is when it gets HOT rather the engine is running or not.
- DiamondSkyBlue1000
Last edit: 20 Oct 2012 00:00 by DiamondSkyBlue1000.
- RonKZ650
19 Oct 2012 18:19 - 19 Oct 2012 18:30Del_Herring wrote: I respectfully disagree with Ron. Running too much voltage through a fuse can cause it to get hot. If the voltage is higher than it should be, current's going to increase, and it'll get hot. That's how fuses work, when they get too hot they pop, whether or not 17 volts is enough of an overage to cause a notable increase in heat, I'm less sure, but it's a problem that should be corrected either way.
I disagree with your disagreement.
Last edit: 19 Oct 2012 18:30 by RonKZ650.
- Powerstroke_fan
19 Oct 2012 19:29
I would just change the reg and then if necassary change the fuse block. All i know is 14-15v is to high for the bike not running.
1977 KZ 1000 work in progress
- built408
21 Oct 2012 13:34Attachment 04.jpg not found
Attachment 03.jpg not found
Attachment 02.jpg not found
Thanks guys!!! I orderd the rec/reg combo from z1 Im gonna whate for it to arrive than order the blade fuse box from CWS . I did a check on my fuse box with my fuse out and ignition on and the pic shows what I have. Let me know what you think. Thanks!!!! Paul
21 Oct 2012 15:04
Voltage might drop when passing between the main fuse clips, but there are several other connections and switches after the main fuse where voltage may be dropping before reaching the ignition coil.
