Hot fuse problem.
- DiamondSkyBlue1000
Last edit: 19 Oct 2012 23:59 by DiamondSkyBlue1000.
Re: Hot fuse problem.
18 Oct 2012 20:17
17v is too high! Your voltage regulator is not working. It should reduce the voltage just as it passes 15v and not allow it to exceed 15v. Ed
- built408
18 Oct 2012 20:24
Ya let me know about the combo unit. Where to buy one maybe. How can I tell if its a combo unit.
1978 KZ1000 A2A with MKII body you know you like it
18 Oct 2012 20:30 - 18 Oct 2012 20:31
From Z1E's listings:
www.z1enterprises.com/ItemDetails.aspx?i...f1000&item=PM81-4081
www.z1enterprises.com/ItemDetails.aspx?i...n+unit&item=RI10-515
Last edit: 18 Oct 2012 20:31 by Patton.
The following user(s) said Thank You: built408
- built408
18 Oct 2012 21:06
Hey thanks Patton! In your oppinion which one is better?
18 Oct 2012 21:15I prefer and use the "plug and play" model that doesn't require splicing, etc., at least when fitted to a relatively stock wiring environment.built408 wrote: ...which one is better?
- 4TheKZ1000
18 Oct 2012 22:02DiamondSkyBlue1000 wrote: The PM81-4081 unit, the one with the green connector already on it.
+1
- RonKZ650
19 Oct 2012 00:27
The regulator may be bad or your meter is bad, but either way this has absolutely nothing to do with a hot fuse. Hot fuse is the clips, period. Like I said before, the fuse runs pretty warm in normal operation, any deficiency in contact and you have a soldering iron going there. There is simply no other possibility, regulator, shorted wiring, any other scenario one could think, none can cause the fuse to run hot, only the clips. So there is my opinion on the subject.
Last edit: 20 Oct 2012 00:00 by DiamondSkyBlue1000.
- mark1122
- Keep twisting it
19 Oct 2012 08:26 - 19 Oct 2012 08:27
double post deleted
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 19 Oct 2012 08:27 by mark1122.
