Hot fuse problem.
- built408
1978 KZ1000 A2A with MKII body you know you like it
- RonKZ650
- Thank you received: 240
- Thank you received: 2829
- built408
built408 wrote: I'm talking melting plastic hot!!! I'll try the polish trick my fuse is held in tight so I know its not loose
I know (see pic). That's why I asked about the wattage of the H4 bulb. Ed
Attachment BurntConnector.jpg not found
- 4TheKZ1000
- Visitor
- 4TheKZ1000
- Visitor
hey Ed...did your main 20 amp fuse have any problems during this problems.
- built408
- built408
Believe it or not, no; it never did blow a fuse. I had been using an off-road only 100w (high beam) H4 bulb that lit up the night like an aircraft landing light. It worked great, but the bulbs only lasted a season or so before blowing; I think due to vibration? I gave up on them and switched to a normal wattage bulb without knowing about the overheated connector. I found the burned connector when doing some other maintenance on the bike. The connector actually still worked fine but clearly things were getting pretty hot using the 100w bulbs. I replaced the connector with an identical one. Ed
- 4TheKZ1000
- Visitor
thanks for help
- Motor Head
- Thank you received: 391
