- Thank you received: 4
Headlight low beam gone, what are the options?
- KZ1000inaus
- Luminous Red KZ1000 A2
Can anyone let me know what the options are for replacing it with another more modern type unit as it was pretty dim anyway.
- wireman
- Thank you received: 299
- bountyhunter
- Thank you received: 337
- boatdrinks
- Thank you received: 54
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
- KZ1000inaus
I can't stick a bulb in there as it's a sealed beam.! so the whole headlight is one big bulbwireman wrote: Buy a regular round halogen replacement bulb and stick it right in there,a 70s chevy truck halogen bulb fits also if you cant find kawasaki listing.
like this one
- KZ1000inaus
ahh i see yea that looks like the right thingbountyhunter wrote: Same wattage, at least 2X as bright. Cheap drop in.
www.summitracing.com/parts/WAG-H6024/
i'll see if i can find one in Aus
- boatdrinks
Charles
Madison, AL
- Thank you received: 2829
+1 These really do work well. Ed
- boatdrinks
Charles
Madison, AL
- wireman
The bulb Im referring to is a sealed beam,millions of trucks used them in the 60s-70s it goes in just like the stock headlight.KZ1000inaus wrote:
like this one
Attachment 7513070003_large.jpg not found
No idea whos truck this is,just used the picture to show you the head light/bulb is the same as the kawasaki unit
- les holt
- Thank you received: 288
Les
- bountyhunter
Any light labeled H6024 will probably be right regardless of manufacturer. The "H" means halogen and the 6024 is a standard size code.
