Non Sealed Battery To Sealed Battery
- MFolks
Re: Non Sealed Battery To Sealed Battery
07 Sep 2012 16:25
Try another reading with the meter held futher back from the bike. Some Dital meters are sensitive to the magnetic field from the alternator, and may give wrong readings. 14.5 volts is the max you should see.
Here's a troubleshooting procedure from electrosport:
www.electrosport.com/technical-resources.../fault-finding-guide
- 4TheKZ1000
- 4TheKZ1000
07 Sep 2012 21:23
multimeter 3 feet from engine...same 13.6 volts at 3000 rpm....
- nobody
07 Sep 2012 22:49
i have tried the Scorpion i like them no problem
The following user(s) said Thank You: 4TheKZ1000
