Non Sealed Battery To Sealed Battery
- 4TheKZ1000
- Visitor
I would like to replace mine with a sealed battery. I ask the fourm for their thoughts on a quality battery....would like a med to high CCA batt.
Thanks, Spencer
- ramtough_63
X2 Power X2-15L I will buy another when needed
Item number: X2-15L
Weight: 11.0000 lbs
Voltage: 12V
Capacity: 14AH
CCA: 220
Primary Applications: Motorcycle, ATV, Jet ski and more
Replaces: 12V14LB, 44005, CB14LA2FP, CYL12N143AXT, CYL14LA2XT, GT14LBS, IB14LA2, M62H4L, X2-15L, XTA14AHLBS, YTX14AHLBS, YTX14HLBS, YUEM62H4L, YXT14AH(L)
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- MFolks
- Thank you received: 540
Dry Cell Motorcycle Batteries
en.wikipedia.org/wiki/Lithium_iron_phosphate_battery (Information)
www.batterystuff.com/batteries/motorcycle/kawasaki/
www.pegasusautoracing.com/group.asp?GroupID=BALLISTICEVO2
www.ballisticparts.com/products/batteries/12cell.html
www.spencercycle.com/category-s/232.htm
www.shoraipower.com/t-faq.aspx (information)
www.shoraipower.com
- Tomolu5
- Thank you received: 45
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- Motor Head
- Thank you received: 391
- 4TheKZ1000
- Visitor
Motor Head wrote: With the wet battery causing your corrosion. Make sure your charging system is not Overcharging/ boiling the battery etc. The new battery won't care for it much if it is.
I will test it tommorow...didnt think of it....thanks....
- bountyhunter
- Thank you received: 337
Correct. The only way a wet cell will spit acid is either:Motor Head wrote: With the wet battery causing your corrosion. Make sure your charging system is not Overcharging/ boiling the battery etc. The new battery won't care for it much if it is.
1) it was overfilled
2) It was overcharged
And the word "sealed" is a bit of an illusion: all rechargeable batteries I know of have vents that open when they are overcharged (which builds up pressure inside). Without said vents they would blow up like an IED. Some sealed lead-acid batteries have a gelled electrolyte as opposed to liquid and they can be mounted at any angle. HOWEVER: many so-called "sealed" batteries have liquid electrolyte and cannot.
- 4TheKZ1000
- Visitor
- bountyhunter
Don't know but it's really easy to test: rev engine to about 3K and measure battery voltage: should be 14V +/- 0.5V. Higher than that and the reg is not working.4TheKZ1000 wrote: ok, I did purchase a combo unit rect / reg from Z1-E. Have these caused any probs that we know about....?
- boatdrinks
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
- Killman
- Now with 99% more ducks
- Thank you received: 12
1983 kz440 ltd
Quack
- 4TheKZ1000
- Visitor
I just checked the battery charge. It came out at 13.7 volts ....I set the multimeter at VDC-20 and put the black led on the neg batt post and red on the poss post....rev the bike to 3000 rpm and took the reading....really dont think its the regulator...thats well within the range....?
