Various Electrical Problems - 83 KZ1000
- MFolks
Re: Various Electrical Problems - 83 KZ1000
04 Sep 2012 15:10
Ohm Checking Pickup(Pulsing) Coils
The pickup(Pulsing) coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(BEHIND A RIGHT SIDE, CD SIZED ENGINE COVER) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
- gaillarry
17 Sep 2012 13:02
Finally found time to get back to the bike. Pickup coils check out ok. Now got another problem.
From the starter relay there are two main wires on the positive cable, red/white and white red, I have power on these two cables, but no power on the two small wires from the relay black and a black/white - shouldn't there be power on these?
1977 KZ1000
1985 Gpz750
1985 Gpz750
- Motor Head
17 Sep 2012 16:27
Those two small wires, one will be ground and the other positive, but hot only at Key On and the Clutch pulled in. There is a pdf service manual in my signature that will have the wiring. or go to "File Base" here in the upper right corner.
