Ohh My God "Let There Be Light"
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
17 Aug 2012 22:20 - 17 Aug 2012 22:51
#543170
Went for a first night ride. I couldnt see SH_T. Gots to be a better light/system for these dino's.
I dont feel that the electrical system is to fault as the volt meter readings are very good and at spec and better. Light burns bright at any RPM and dosent dim.
Made me feel nervous....as can people see me comming? Cause I cant see that object in the road.
Whats working for the forum riders.
Thanks, Spencer
Last edit: 17 Aug 2012 22:51 by 4TheKZ1000.
  • wireman
  • wireman's Avatar
Re: Ohh My God "Let There Be Light"
17 Aug 2012 22:59
#543176
Ive always had good luck with automotive style halogen lights,same light used in 70s chevy trucks B)
The following user(s) said Thank You: 4TheKZ1000
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
17 Aug 2012 23:02
#543177
I installed an HID headlight and a full LED conversation elsewhere.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • 4TheKZ1000
17 Aug 2012 23:13
#543184
Wireman...is that a H4 conversion with small bulb or is it a sealed 3 prong 7" bulb like stock?
  • wireman
  • wireman's Avatar
17 Aug 2012 23:21
#543187
Plugs in just like origional light bulb,Ive always figured if they can survive the abuse Ive subjected them to in dump trucks and 4x4s over the years theyre plenty stout for a bike.
Ive used them in all my bikes over the years without mechanical issues. B)
  • 4TheKZ1000
17 Aug 2012 23:35 - 17 Aug 2012 23:48
#543189
will this work???
THIS LISTING IS FOR A H6024 7" 12 VOLT HIGH/LOW BEAM CRYSTAL CLEAR SEMI-SEALED BEAM HALOGEN HEADLIGHTS, INCLUDES ULTRA WHITE BULBS 85/80W. THESE ARE GLASS FACED HEADLIGHTS. THESE LIGHT UP 50% BRIGHTER AND LIGHT UP A LITTLE MORE WHITE THEN THE STANDARD STOCK STYLE INCANDESCENT HEADLIGHT BULBS. THESE HAVE THE ORIGINAL 3 PRONG PLUG DESIGN ON THE BACK SO THEY WILL PLUG RIGHT INTO THE ORIGINAL WIRING HARNESS. THESE WILL FIT ANY CAR OR TRUCK THAT HAS 2 ROUND GLASS HEADLIGHTS THAT ARE 7 INCHES IN DIAMETER. THESE ARE GLASS AND WE WILL TAKE EXTRA CAR IN PACKAGING.
Attachment bolb.jpg not found
Last edit: 17 Aug 2012 23:48 by 4TheKZ1000.
  • wireman
  • wireman's Avatar
17 Aug 2012 23:35
#543190
Heres one I found on flea bay,fits just like stock bulb but a whole lot brighter.
Attachment 51AopkTgNbL__SL500_AA300_.jpg not found
  • 4TheKZ1000
17 Aug 2012 23:46
#543196
I would like to go as bright as I can or the bike will allow B)
  • mtbspeedfreak
17 Aug 2012 23:55
#543197
4TheKZ1000 wrote: I would like to go as bright as I can or the bike will allow B)
That would be HID.
2000 ZRX 1100
  • 4TheKZ1000
18 Aug 2012 00:09 - 18 Aug 2012 00:10
#543201
I found a HID system for $50....is this correct....that cheap? see below
Attachment 219232.gif not found
Last edit: 18 Aug 2012 00:10 by 4TheKZ1000.
  • bountyhunter
  • bountyhunter's Avatar
18 Aug 2012 01:42 - 18 Aug 2012 01:45
#543218
4TheKZ1000 wrote: Went for a first night ride. I couldnt see SH_T. Gots to be a better light/system for these dino's.
Thanks, Spencer
Right here: www.summitracing.com/parts/WAG-H6024/
No modifications, same wattage, much brighter. $12
Last edit: 18 Aug 2012 01:45 by bountyhunter.
19 Aug 2012 23:26
#543521
Thanks, Spencer
+1 ! I've been using the Wagner sealed halogens for years and they work great for small $$$.
