misfires again
- hiroshima1320
Re: misfires again
04 Aug 2012 23:15
I think I squeezed a little too hard on the #1 needle seat in the carb getting it back out, now my needle won't move properly... :blush:
Stop dreaming the life. Start living the dream.
- hiroshima1320
Re: misfires again
06 Aug 2012 23:20
I'm lost. I cleaned out the carbs again, reset the floats and the 2&3 pipes are cooler than 1&4. I have the pipes wrapped, so I just touched them with my hands, it runs kinda rough at low rpm but seems fine above about 4k... In am tired of working on this thing. It's the same shit over and over again.
- badrhino
Re: misfires again
10 Aug 2012 22:07
I know how you feel. I am having an issue with #4 on mine. It won't run as hot as the other and I have tried/done everything except buy new coils. I have already spent too much time and money on this bike. I might just sell it. :S
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- Old Man Rock
Re: misfires again
11 Aug 2012 09:36 - 11 Aug 2012 09:37
Maybe I missed, so I'll ask anyways...
Fuel float levels good on the suspicious carbs...?
Carb sync to spec...?
Rubber sync caps pliable or hard thus vacuum leak... ?
Intake boots sealing ideally...?
Pod air filters or OEM airbox...?
Ignition pick ups to spec...?
Ignition timing and camshaft pin counts correct (not off a tooth)...?
Once the coils are hot, check resistance measurements (primary & secondary match other working coil)...?
Place a timing light on plug wires 1 - 4... and verify idle and advance mark is being obtained (ignition cover/advancer)....Get the same results....?
What are the saprk plug conditions between good and bad cylinders...?
You have a Color Tune for viewing chamber ignition spark...?
Seems to me you still have some considerable t-shoot/testing to confirm yet... Don't give up quite yet for carbs are a bitch to learn, takes time & patients so get after it...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 11 Aug 2012 09:37 by Old Man Rock.
