How do u convert a '78 Z1R to electronic ignition?
  • 300kph
  • 300kph's Avatar Topic Author
23 Jul 2012 18:28 - 23 Jul 2012 18:36
#537965
I am having some spark issues and I suppose the cheapest fix is a new breaker plate, points and condensors but would anyone claim advantage to going electronic?
In a perfect world I would like to use Kawasaki parts from perhaps the MKII?
Ignition is one thing I do not know much about but I know my old point set is needing either replacement or upgrade.
I've seen talk of the Dyna S set-up and heard pros and cons.
Would like to stick with Kawi parts if there are parts that cross over properly... can this be done? What is all required? Would I need coils? if I go the CDI route?
WHAT ABOUT THIS: Could I take the parts from my MKII (which is not currently licensed) and use them? Would I then find myself stuck trying to get replacement parts for the MKII?
Help please.
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
Last edit: 23 Jul 2012 18:36 by 300kph.
  • wireman
  • wireman's Avatar
Re: How do u convert a '78 Z1R to electronic ignition?
23 Jul 2012 18:39
#537970
It would definately be more reliable with electronic ignition,and yes if your MKII isnt running Id use the parts off of it.
If nothing else it will help eliminate other possible issues without having to spend a bunch of money on parts. B)
  • 300kph
23 Jul 2012 19:00
#537977
Exactly what parts will I need to grab off the MKII and what is the liklihood of finding replacements?
Wayne
1978 Yamaha XS1100
  • trianglelaguna
  • trianglelaguna's Avatar
23 Jul 2012 20:28
#537993
why not just put and dyna s and dyna coils and be done with it forever
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • wireman
  • wireman's Avatar
23 Jul 2012 22:21
#538032
Coils,ignition plate/parts under points cover,factory igniter,maybe ballast resistor from under back bone area of frame. B)
  • wireman
  • wireman's Avatar
23 Jul 2012 22:23
#538034
trianglelaguna wrote: why not just put and dyna s and dyna coils and be done with it forever
It all costs money and if your trying to dianose a problem its a lot easier/cheaper to try it with existing parts instead of just throwing $$$$$$$$$$$$$$'s and parts you already have at it. B)
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
23 Jul 2012 22:24
#538036
Can't I just like this post? lol
Don't take parts off of a bike that you plan on riding. I have had my dyna ignition on my bike for over 20 years. IT WORKS GREAT! Points suck IMHO. I had them on my 69 stang and they are more expensive in the long run to maintain.
Of course, if you don't want to spend a lot of money then rape your poor MKII but later when you want to ride that then what? You can find used ones for a good price although I buy new.
79 LTD B3
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
23 Jul 2012 22:30 - 23 Jul 2012 22:31
#538037
Nothings forever.
I've been with points, Dyna S, back to points, and now with Kawi elec. Ign.
My Dyna fried on me.
I was warming up my bike and she started smoking from behind the points cover.
Turned the bike off, and opened the cover to find one of the pick ups fried.
This was over ten years ago, and at the time I did not try to contact Dyna for repair, I've heard of others having some success getting repairs under warrantee.
At the time this happened to my Dyna, I had had it for 5 or more years, and was not really riding regularly, so did not even think of contacting Dyna.
Parts you need for a Kawi elec. Ign:
Pick ups and mounting plate.
Ic Igniter.
Coils suiteable for such ignition.
Plus the related wiring and plugs.
I converted my 650 first using a kz1000 mounting plate made smaller, then a 650 plate later on.
KZ IC Igniters from the '79 to '82 time frame are mostly the same.
Here's a long post about it:
forums.kz650.info/index.php?topic=12.0
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 23 Jul 2012 22:31 by rstnick.
  • wireman
  • wireman's Avatar
23 Jul 2012 22:32
#538039
The replacement parts arent that hard to find,but since hes got them sitting there to try out it doesnt cost him anything right now.
Then he has a better idea of what the problem is.
What happens when he breaks down and buys a new ignition and all the other related parts and finds out its a carb related issue after dumping $400-$500 in ignition parts into it? :sick:
Hell most of the guys on here have a tough time bringing themselves to spend money on a $15.00 valve cover gasket to stop an oil leak,but when its somebody else spending the money theyre all for it! :laugh:
Craig you cheap bastard I know you wouldnt shell out for an ignition system if you had a spare sitting in your garage you werent using! :woohoo:
The following user(s) said Thank You: saxjonz
  • trianglelaguna
23 Jul 2012 22:45
#538043
got to get to bed early so i can go put my 800 dollars worth of parts on in the morning... :P
oh and the parts i'm replacing are in working order......
1976 KZ900
2003 ZX12R
2007 FZ1000
  • wireman
  • wireman's Avatar
23 Jul 2012 22:47
#538044
Yeah Ive seen your garage ya cheap bastard! :laugh:
  • trianglelaguna
24 Jul 2012 01:00
#538117
everything is gone
everything
i thought you knew?
i am a free man...unlike you....
i have no extras...and will keep nothing
the tires will get tossed or given away here
the shocks will be amy's first new sale on ebay
where i got a dyna s used for under 70 and coils once for under a 100 new
now back to the elec deal.....what does it matter...he can do what he wants for sure...but the kawi stock set up is more parts to work out,...the dyna is install ,time ,and swap coils....you only need to make or use the plug wires to match your bike and the coils need a few wires and connectors to mate to the harness..auto store stuff or clip the old ones and mount em.....
i dont doubt that some dynas have turded but in general they are the best for these old kawis.....90% of bikes have em...or need em just about
1976 KZ900
2003 ZX12R
2007 FZ1000
