KZ440 Starter - seems like a dead battery but isnt
- splazoid
23 Jul 2012 00:53
Hello everyone - recently got a 1980 KZ440 A1 LTD fixer bike.
Starter turns over really slowly, sounding almost as though the battery is really close to dead, although the battery was replaced by PO this year and holds a good charge.
Eventually the bike will fire, but begrudgingly - runs like a top once it does though.
Where do I begin to fix this issue - not worked on starter systems before and eager to dig in.
Re: KZ440 Starter - seems like a dead battery but isnt
23 Jul 2012 10:25
Check all connections between the battery and starter and the battery to ground Clean and re-tighten them. Also, make sure the battery is the correct size (in amp hours) for your bike. Ed
- splazoid
23 Jul 2012 23:07 - 23 Jul 2012 23:08
I've confirmed it's a 12 amp battery, holding really good volts and I've also cleaned and retightened the connections.
No dice - still cranks over really lethargicly, but eventually does fire.
I'm going to try testing the starter relay as outlined in the Clymer - other ideas?
Last edit: 23 Jul 2012 23:08 by splazoid.
23 Jul 2012 23:10
Does it only do this when the engine is cold? Ed
- splazoid
23 Jul 2012 23:12
No, but it does start with less cranks when warm, as one might expect, although they are still very slow.
Would it help if I took a video with sound?
- trianglelaguna
23 Jul 2012 23:18 - 23 Jul 2012 23:18
1st thing to try
do you know how to use a screwdriver on the starter relay...solenoid
2nd
is the headlight on when the key is on..if so take the two screws that hold the headlight rim on ,off,and unplug the light and set it aside...if the bike fires right up then the battery is the deal...even though the battery checks out...if the light is on before the bike starts....try unplugging it
2nd
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 23 Jul 2012 23:18 by trianglelaguna.
- splazoid
24 Jul 2012 16:42 - 24 Jul 2012 16:44
Thank you so very much for all your help ED
Alright, after digging a bit more, checking all the wires at the battery and the solenoid, I have confirmed that the solenoid clicks nicely, the starter switch works well, and a good battery.
Headlight being removed made no difference, trianglelaguna
Now the solenoid clicks, but the starter motor doesn't engage at all anymore. I have not dug into the motor yet to check it's connection to the solenoid - is that my next step, or is it pretty likely I will need a rebuild kit for the starter motor?
Last edit: 24 Jul 2012 16:44 by splazoid.
