starter problem
  • bradley77
  • bradley77's Avatar Topic Author
  • 1977 kz650c
starter problem
19 Jun 2012 17:40
#530374
i have a 77 kz650c and when it is cold or bike hasnt been started for a day or two, and i go to start with electric start it makes a clanking noise and does till is started but when bike is warm it starts right up with lttle clanking any ideas wht the problem is??????
  • Motor Head
  • Motor Head's Avatar
Re: starter problem
19 Jun 2012 22:06
#530412
I would pull off the side cover and look at the chain, and gears. Could be a worn chain, or guide.
Re: starter problem
19 Jun 2012 22:13
#530416
Motor Head wrote: I would pull off the side cover and look at the chain, and gears. Could be a worn chain, or guide.
Which chain? KZ650 starters use a starter clutch mechanism that is known to make noise when it gets some wear on it and slips. Ed
  • Motor Head
Re: starter problem
19 Jun 2012 22:20
#530423
Sorry I thought those had a chain? Disregard then.
  • bradley77
  • 1977 kz650c
Re: starter problem
19 Jun 2012 23:41
#530440
so what should i do
Re: starter problem
20 Jun 2012 09:38
#530494
If you can positively identify that the noise is coming from the starter clutch you may want to replace the appropriate pieces. Take a look at the links in the posting below for info on how to do it:
kzrider.com/forum/2-engine/528029-funky-noise#528054
  • Jonny
  • Jonny's Avatar
  • woot!
Re: starter problem
29 Jun 2012 00:27
#532518
Sooo, is it suggestive of a failing starter clutch if when using the electric start, is does not always engage fully, and at other times makes a sound something like a Transformer with a smokers cough?
If so, then:
A) Damnit. Just put in fresh oil and want to go riding after a very difficult spring maintenance session.
B) Thank you Ma Kaw for the kickstart.
Cheers.
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
