brake light pressure switch
  • jtp103
  • jtp103's Avatar Topic Author
  • John The Polock
02 Jun 2012 03:17
#526403
:unsure: My 78 KZ1000 A2A,has a hydraulic pressure switch on the front brake line.I have to put on quite a bit of braking pressure for the brake light to operate.Is there a way to make the pressure switch more sensitive. Sometimes I can come to almost a full stop without it functioning.
  • MFolks
  • MFolks's Avatar
Re: brake light pressure switch
02 Jun 2012 15:22
#526457
I'd replace the switch if possible as it's probably failing. www.kandstech.com/index.php?page=brakeswitches makes replacement switches
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
02 Jun 2012 15:29
#526458
In a word, no.
It could be the switch is faulty from being gunked up or your wiring is degraded (dirty connections and the like). Put a meter on it and measure the resistance across its terminals while you activate the brake to determine whether it's the switch or the wiring.
I don't suspect that you're not getting enough pressure to activate the switch because you mentioned the brakes work up front.
You can buy a replacement one here.
You can buy a different setup that eliminates the splitter entirely here.
  • bountyhunter
  • bountyhunter's Avatar
02 Jun 2012 16:03
#526460
jtp103 wrote: :unsure: My 78 KZ1000 A2A,has a hydraulic pressure switch on the front brake line.I have to put on quite a bit of braking pressure for the brake light to operate.Is there a way to make the pressure switch more sensitive. Sometimes I can come to almost a full stop without it functioning.
My 79 KZ750 is the same ever since it was new. I don't think the switch is adjustable
