rewiring 82 kz750 ltd
- kz750ohio
28 May 2012 12:09
Good Morning everyone,
I have a 1982 KZ750 LTD. Great running bike after the wonderful help I have received from this forum. The question I have is do they make a aftermarket wiring harness for my bike. If not where do you recommend I go for parts and connections. The reason I ask is for my winter project I plan to rewire the old girl. Over the last couple of years I have had to wire in some new wire along the way to get 12 volts in certain area's. I thought for this winter project I would rewire the whole bike. Replace the main fuse area with blade fuses instead of the glass ones and replace all the old worn out wiring from being 30 years old. Any help or guidance is appreciated. I thought I would get a jump on getting stuff together for my project.
Also on a side note I just picked up my (classic motorcycle) plates from the DMV and all I can say is cool.
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
- MFolks
Re: rewiring 82 kz750 ltd
28 May 2012 15:15
Some information about needed tools:
Motorcycle Wire Repair Kit
Multimeters
www.radioshack.com/product/index.jsp?productId=2999093
(17 Range Analog Multimeter)
www.radioshack.com/product/index.jsp?productId=4214667
(15 Range Digital Multimeter)
www.radioshack.com/product/index.jsp?productId=2103176
(29 Range Digital Multimeter)
www.stanleysupplyservices.com/product-group.aspx?id=1563 (Heat Gun)
www.wiringproducts.com/contents/en-us/d193.html
(Heat Guns)
www.buyheatshrink.com/HeatGuns/heatguns.htm
(Heat Guns)
www.silverstatewire.com/1826.html
(Heat Guns)
www.wiringproducts.com/contents/en-us/d4...PV9agCFQpm7AodClsxWg
(Butt Connectors or Splices)
cableorganizer.com/krimpa-seal/
whiteproducts.com/splices.shtml
www.sherco-auto.com/krimpaseal.htm
(Crimpable Butt & Heat Shrink Splices)
www.shrinktek.com/docs/ProductTemplate.aspx?product_id=Splices (Heat Shrinkable Butt Connectors or Splices)
www.parts-express.com/wizards/searchResu...n%20butt%20connector
www.wiringproducts.com/contents/en-us/d41.html
(Crimping Tools)
www.defender.com/product.jsp?path=-1|328|49758|319689&id=336039
(Crimping Tool 22-18,16-14, & 12-10 Gauge)
cableorganizer.com/heat-shrink-crimping-tool/
(Crimping Tool, 22-18,16-14,12-10 & 8 Gauge)
www.sailorssolutions.com/index.asp?page=...ctDetails&Item=WP042
(Crimping Tool, For Heatshrinkable Terminals, 22-18,16-14, &
12-10 Gauge)
www.corsa-technic.com/item.php?item_id=370&category_id=86
(Crimping Tool, For Insulated Terminals, 22-18,16-14 & 12-10 gauge)
www.delcity.net/store/Ratchet!style-Crimping-Tools/p_10382.a_1
(Ratcheting Crimping Tools, For Insulated Terminals,22-18,16-14 &12-10)
www.corsa-technic.com/item.php?item_id=369&category_id=86
(Crimping Tool, For Non Insulated Terminals 22-18,16-14, & 12-10 Gauge)
(Crimping Tool, For Insulated Terminals 22-18,16-14 & 12-10 Gauge)
www.wiringproducts.com/contents/en-us/d75.html
(Wire & Cable Cutters)
www.wiringproducts.com/contents/en-us/d76.html
(Wire Insulation Strippers)
www.idealindustries.com/products/wire_pr...ools/stripmaster.jsp (Wire Insulation Strippers)
www.pbase.com/mainecruising/wire_termination
(The Good, Bad, & Ugly Wire Crimpers)
Non adhesive harness/loom tape
www.dormanproducts.com/p-13830-85274.aspx
www.pcsconnectors.com/harness_tape.aspx
www.deadnutson.com/catalog/item/2965331/6122491.htm
www.tapebrothers.com
www.wiringharness.com
www.findtape.com/shop/product.aspx?id=32...&width=1436&height=0
Electrical Connectors, Wire, And supplies
www.easternbeaver.com
www.qualitycycleparts.com/
www.vintageconnections.com
www.z1enterprises.com/catalog.aspx?pid=KPEL1
www.vehicle-wiring-products.eu
www.electricalconnection.com
www.electricalconnection.com/electrical-components/hitachi.htm
www.hvccycle.com/electrical-connectors.html
www.terminalsupplyco.com
www.pbase.com/mainecruising/wire_termination&page=1
www.crowbarelectricalparts.com/butt_connectors.htm
www.terminaltown.com
www.electerm.com
www.autoelectricsupplies.co.uk
www.painlessperformance.com
www.rallylights.com
www.ironbutt.org/forum/forum_posts.asp?TID=1759&PN=1
www.ratwell.com/technical/Terminals.html
www.economycycle.com/servlet/the-Bullet-...lectrical/Categories
Multimeters
(Heat Guns)
(Heat Guns)
(Heat Guns)
(Crimping Tools)
12-10 Gauge)
www.electerm.com
www.rallylights.com
- MFolks
28 May 2012 15:17
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by using a multimeter to check for voltage going through the fuse, or when the fuse is removed for physical inspection for tight end caps & continuity checks,can it be determined if it’s serviceable.
5. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
6. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
7. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
8. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net/store/6!way-fuse-blocks/p_10822.a_1
www.easternbeaver.com/Main/Elec__Product...ers/fuseholders.html
www.autowiringsolutions.com/item.php?item_id=251&category_id=89 (ATO/ATC Fuse Holder)
9. A source for the glass tubed AGX fuses:
www.boatownerswarehouse.com/browse.cfm/2,4986.html
www.napaonline.com/Catalog/Result.aspx?N...&D=AGX&Dk=1&Dp=3&N=0
- MFolks
28 May 2012 15:23
Cleaning Motorcycle Electrics
1. Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. It can be purchased at most Radio Shack Stores or any electronic supply places. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
2. On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
3. Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
4. However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach. Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
5. Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
6. Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
7. Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
8. If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
9. The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start. The older Kawasaki’s have reports of the soldered connections crumbling, if your bike has this problem, just ask, as I’ve got a repair procedure for this.
10. Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
11. The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
12. If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
13. Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting). I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
14. All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
15. Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
16. If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
17. Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
18. The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
20. The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
21. Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
22. Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
- MFolks
28 May 2012 15:26
Read this for a primer on hand soldering:
technologyinterface.nmsu.edu/fall97/electronics/solder.html
Repairing Motorcycle Soldered Connections on the older bikes.
When repairing soldered wires on motorcycle switches or light bulbs sockets, have the following on hand:
1. A 25 Watt soldering iron or one that the wattage can be adjusted.
2. Rosin core solder of 60/40 type. SN60 or SN63 is preferred.
3. Rosin flux or soldering paste (Never use solder or soldering paste designed for plumbing work, as it contains an acid that will corrode the electrical joint, ruining it).
4. 91% rubbing Alcohol, or 70%. The lower percentage will clean up flux residue, but not as good as the higher percentage stuff. Acetone does a good job of removing excess solder flux too.
5. A cut down ½” paint brush, or acid brush for scrubbing the repaired solder joint.
6. Clean rags or paper towels
7. A damp sponge to keep the soldering iron tip clean.
8. Some “Solder Wick” a braided bare copper wire designed to collect heated excess solder, aiding in joint preperation, available at electronic supply stores.
9. Some wooden toothpicks.
10. Small Hemostats or clip on heatsinks.
A. Before soldering, “Tin” the soldering iron tip by plugging it in or turning the iron on, allowing it to get to operating temperature(2-3 minutes).
B. Unroll about 3” of solder from the roll of rosin core solder & then using a clean rag or paper towel moistened with Alcohol, wipe the unrolled solder, removing the finger print oils that will create a poor solder joint.
C. Apply a small amount of solder to the now heated soldering iron tip, wiping the excess off with the wet sponge, keeping a thin layer on the soldering iron.
D. The soldering iron is now ready for use, but before applying the heated tip to a wire, wipe the tip on the damp sponge, this removes any oxidized solder and makes for a much better connection.
E. If the joint to be repaired is grey in color or appears “Crumbled”, apply some rosin soldering paste or flux to the joint with a small toothpick or screwdriver, and then apply the soldering iron tip for a few seconds.
G. The fluxed joint should clean up, allowing for a better connection. If no luck, use the solder wick to remove all traces of the old solder by apply in it between the soldering iron tip and the bad joint.
H. Hemostats and clip on heatsinks will be used to prevent the wire insulation from burning, overheating & pulling away from the connection.
I. Apply a small amount of flux to the joint to be repaired & then a very short duration of heated soldering iron tip & solder(like a few seconds or so).
J. Clean off the repaired joint with the brush & rubbing Alcohol or Acetone, the newly repaired joint should appear clean and bright, almost as if it were polished, with no voids or holes.
K. When repairing the bad or "Cold Solder Joints" (as the Electronics industry calls them), it takes really no special skills, just patience, and a place to work(along with the mentioned tools. You've got to be sober, and not stoned, as the soldering tool can be at 700 F, possibly giving the impaired bike owner severe burns.
L. If you have fine muscle control problems, have a friend do the soldering for you. Moving a wire before the electrical joint has properly set up, can create "Cold Joints" too. If possible, practice on the bench top with some scrap wires before attempting repairs on the bike.
M. This information comes from years of missile test cable and equipment assembly, when I worked at General Dynamics/Convair Division in San Diego California, on the BGM-109 Tomahawk and later on the AGM-129 Advanced Cruise Missile. This was from 1983-1993. The company had a week long soldering school, where you learned to solder meeting “Mil-Spec” standards.
