Dyna S Kz1000
  • Ogcoda
  • Ogcoda's Avatar Topic Author
  • Killing Everything
Dyna S Kz1000
18 Apr 2012 14:17
#516491
So I have been doing some searching around and found that the Dyna S Ignition system is probably the best way to go for my bike. Just want to know if there is anything I should watch out for. I am looking for a reliable route and i really don't want to have to mess with the timing... so what am wondering is.... Do I need the Coils and the points or just the points replacement part?
1978 kz1000 Bobber
2006 MazdaSpeed6
  • ramtough_63
  • ramtough_63's Avatar
Re: Dyna S Kz1000
18 Apr 2012 15:15
#516505
I just installed the Dyna S with 30 year old Andrews coils I'm not sure what the ohm rating on your present coils are but the Dyna reccommends 3 ohm coils so if yours are 2.2 ohm I would replace them.
But then again I am gonna replace mine as soon as the financial situations allows for it new couils new wires and new ignition should be set it and forget it!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
Re: Dyna S Kz1000
18 Apr 2012 15:19
#516507
I installed a Dyna S and Dyna 3.0 ohm coils (the green ones) awhile back, absolutely no complaints!
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Kawickrice
  • Kawickrice's Avatar
Re: Dyna S Kz1000
18 Apr 2012 15:29
#516509
X2 Converted my 650 and 900 from points to the Dyna S and green coils. I can't believe it took me 25 years to see the light. As far as timing once it is set you are done, set it and forget it.
mtbspeedfreak wrote: I installed a Dyna S and Dyna 3.0 ohm coils (the green ones) awhile back, absolutely no complaints!
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Re: Dyna S Kz1000
18 Apr 2012 16:59
#516526
Ogcoda wrote: So I have been doing some searching around and found that the Dyna S Ignition system is probably the best way to go for my bike. Just want to know if there is anything I should watch out for. I am looking for a reliable route and i really don't want to have to mess with the timing... so what am wondering is.... Do I need the Coils and the points or just the points replacement part?
The stock coils are a match for the Dyna-S electronic ignition.
Provided the stock coils are still in serviceable condition.
However, a typical problem arises because of the old hard cracked spark plug wires that are permanently built into the stock coil as integral components of the coil.
If wanting to add new plug wires to an old stock coil, a plug wire "splicer" is available whereby new wires may be attached to the short stub ends of the old wires.
Imo, the money would be better applied toward new Dyna coils.
Won't hurt anything to try running the old coils (and built-in wires) along with the Dyna-S ignition.
Watch for high intensity voltage leaks through the plug wires, and possible cracks in the old coils.
Good Fortune! :)
  • Ogcoda
Re: Dyna S Kz1000
19 Apr 2012 18:22
#516706
Thanks guys, Helped out alot!
1978 kz1000 Bobber
2006 MazdaSpeed6
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
Re: Dyna S Kz1000
19 Apr 2012 21:07
#516754
I've had mine for 3 years or so now with zero issues. I installed the ignition, coils and wires, I think that's the best way to go. What to watch out for? Just make sure you wire it up properly and lube the advancer periodically. Easy peasy.
