testing charging system?
  • davem
  • davem's Avatar Topic Author
Re: testing charging system?
20 Mar 2012 19:03
#510896
Patton wrote: :unsure: Will the engine run well enough to obtain voltage measurements across the battery posts at idle and at 3000~4000 rpm? And if so, what are the readings?
9.4 @ idle
12.4 at 4000rpm
1979 Kz1000 B3 LTD
1997 Kawasaki police 1000
1985 kz1000p4 project-sold
  • Motor Head
  • Motor Head's Avatar
20 Mar 2012 23:12
#510949
The low, 6v across the battery at key ON, sounds like the battery is in question. Charge the battery at a slow rate overnight, and take it to a shop to have it tested. Most likely you will need a new one from the sounds of it.
It looks like the Voltage is increasing from Idle to 4K when checking at the battery terminals, maybe still low, hard to say with a possible bad battery. Get it checked out next.
  • davem
20 Mar 2012 23:50
#510959
Motor Head wrote: The low, 6v across the battery at key ON, sounds like the battery is in question. Charge the battery at a slow rate overnight, and take it to a shop to have it tested. Most likely you will need a new one from the sounds of it.
battery is 2 days old. I put on tricl charge each night.
1979 Kz1000 B3 LTD
21 Mar 2012 00:11 - 21 Mar 2012 00:12
#510964
davem wrote: ...Volts at battery across post key off 11.5v....
Imo, battery is deficient, for whatever reason.
Could also have the battery load-tested.
And would suggest having this done somewhere other that where the battery was acquired.
Good Fortune! :)
Last edit: 21 Mar 2012 00:12 by Patton.
  • davem
21 Mar 2012 00:21 - 21 Mar 2012 01:00
#510966
Good Fortune! :)
I was having this problem before i bought this battery but I will take it to be tested to be sure.
something else I just noticed...the conector that goes from stator to rectifier regulator is melted just a tad where the black and yellow wire plug in.
1979 Kz1000 B3 LTD
Last edit: 21 Mar 2012 01:00 by davem. Reason: forgot to add something
21 Mar 2012 01:13 - 21 Mar 2012 01:14
#510984
What is battery voltage without cables connected (or with one of the cables disconnected)?
Last edit: 21 Mar 2012 01:14 by Patton.
  • Motor Head
21 Mar 2012 09:50
#511018
Good Fortune! :)
something else I just noticed...the connector that goes from stator to rectifier regulator is melted just a tad where the black and yellow wire plug in.
Any heat damaged wiring will have to be repaired. This may require a new R/R, as it could be 1 leg of the Rectifier, Diode, is bad. This will allow partial charging. You will not get full charging if one of the three internal rectifier circuits has a bad diode. A Diode is like a one way door, inside the rectifier it turns the ACV into DCV. So if one section is bad, then it will drop 30% of its charging current.
Get the battery tested. I assume it is full of electrolyte? That is an Acid pack that can very well be sold separately from the battery. You fill, then let rest, then charge, again resting before install/ use.
  • davem
21 Mar 2012 21:17
#511114
Patton wrote: What is battery voltage without cables connected (or with one of the cables disconnected)?
right now its at 10.8v across terminals with out cables on. I didnt get to check it after I charged it. rode it to my shop and did my test.
Its the same reading when cables are hooked up.
.......I did the alternator stator resistence test thet is in my manual. with key off i get .9 ohms per 2 yellow wire combos of the three. The book says it should be between .5 and .7 what does it mean if its higher.(.9)?
as you recall the test with engine running was to spec.
:sick: :sick: :sick:
1979 Kz1000 B3 LTD
  • davem
22 Mar 2012 00:59
#511175
Good Fortune! :)
I replaced damaged wires. I actually went through the entire wire harness. I replaced the r/r with a spare I had from another bike.
I have the battery charging again and will take tomorrow to be tested without putting in the bike first.... I keep charging it than doing my own testing and so its no longer fully charged so they tell me they can only test it if it is fully charged........
1979 Kz1000 B3 LTD
  • davem
22 Mar 2012 01:20
#511179
OK.... i may have found something but not sure and not sure of solution.
I bypassed the right hand controls(electric start/ kill switch/ect.
when I did this I took the yellow wire that connected to red and yellow to right contols and ran ran it directly to red and yellow bypassing the kill switch. the black wire that came from right controls I grounded to the frame.(this is where i think i made my mistake) I assumed the black was ground. Is it or is it not? On my wire diagram it shows black coming from pos. side of battery.
With that black wire to ground and a fully charged battery the bike will start right up.....
today I tried to rehook up right hand controls (with a spare from another kz) so eliminating my work around. I cant get the bike to start not even fire. but I ground that black wire and she starts right up with the kicker.
But im still having my battery drain fast with key on.
any thoughts?
I hope i explained this all well enough.
thank you all for your help?
1979 Kz1000 B3 LTD
22 Mar 2012 10:50
#511219
Black/yellow is usually the ground.
Would check FILEBASE for a wiring diagram.
Attachment filebasekzr.jpg not found
Good Fortune! :)
  • Old Man Rock
  • Old Man Rock's Avatar
22 Mar 2012 11:46
#511233
Black (Battery Vdc ~)is your conductor from the starter button to the starter relay in reference to black/yellow ground.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
