LED signal stabilizer
12 Mar 2012 23:12 #509310 by gwolever
LED signal stabilizer was created by gwolever
Hey guys. So I was ordering some LED turn signals from some site and they recommended a signal stabilizer unit to go along with the signals I was already buying.
This stabilizer is around $60. Do you guys know if this is something I should get? And is this a reasonable price for such a unit?
I figured there had to be a few of you out there who have switched over to LED signals and might know what to do.
Here is the link to the said stabilizer unit:
www.chromeglow.com/catalog.asp?prodid=624309
Thanks guys.
1982 KZ1000 CSR
12 Mar 2012 23:40 #509318 by pig9r
Replied by pig9r on topic LED signal stabilizer
That will work, but a simpler (and much cheaper) way is to replace the mechanical flasher with a solid state or electronic flasher. If you can't find one there are cheaper load equalizers out there. All they really are is a resistor.
12 Mar 2012 23:41 #509319 by mtbspeedfreak
Replied by mtbspeedfreak on topic LED signal stabilizer
That stabilizer is a HORRIBLE rip off!!!
I bought my bulbs and a no-load flasher unit from superbrightleds.com
I have used the CF-12 flasher for over a year without any problems. I highly recommend it. It's less than $20.
2000 ZRX 1100
1976 KZ 900- Daily Driver
12 Mar 2012 23:41 #509320 by mtbspeedfreak
Don't get the stabilizer or resistor. Putting a resistor in the system will totally negate the largest benefit of LEDs (lower current draw).
2000 ZRX 1100
12 Mar 2012 23:50 #509323 by cfaherty
Replied by cfaherty on topic LED signal stabilizer
When I went LED turn signals I replaced the stock flasher relay with this $4 one from Advance Auto. Plug & Play.
Part #552 Thermal Flasher, Tridon Novita Technologies.
1983 KZ750 F1 LTD Shaft
12 Mar 2012 23:55 #509324 by DaddyJama
Replied by DaddyJama on topic LED signal stabilizer
Or wire a resistor in line..
2005 636 - track bike
1982 kz440ltd - new toy;)
  • BikeDude2002
  • Today is a good day to ride...
13 Mar 2012 01:04 #509355 by BikeDude2002
Replied by BikeDude2002 on topic LED signal stabilizer
Might want to check out the LED compatible flashers on www.cwswiring.com ,check out the product info sheet on the site for more info. The 552 flasher above will likely not fix the problem.
78 KZ650 SR
90 Yamaha Radian
13 Mar 2012 07:48 #509370 by Old Man Rock
Replied by Old Man Rock on topic LED signal stabilizer
I have the EP-35 in mine, ~ $12.
The Speedmetal device would work as well..
As mentioned, load sensitive/LED low current relays are the way to go... Auto parts stores carry them for under $20...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • BikeDude2002
13 Mar 2012 13:54 #509415 by BikeDude2002
Also good options, Rock. CWS wiring version comes with rubber mount that goes on factory tab of battery box, if it is relevant. Also, non load sensitive usually works better, the flash rate is consistent, with load sensitive, you will get different flash rates, depending on your application.
78 KZ650 SR
90 Yamaha Radian
13 Mar 2012 13:57 #509416 by gwolever
Replied by gwolever on topic LED signal stabilizer
Awesome. Thanks for your input guys.
I knew it was a good idea to hold off ordering this stuff until I talked to you guys about it. That would have been a huge mistake and rip-off.
Thanks again guys, as usual you came through with great advice.
1982 KZ1000 CSR
13 Mar 2012 18:00 #509451 by Rampage1967
Replied by Rampage1967 on topic LED signal stabilizer
If your bike has twin turn signal indicator lamps on the dash. Simply install an electronic flasher & LED signal bulbs. Leave the incandescents in the cluster bulbs. Works great, cheap & simple ;-)
1978 Kawasaki KZ650 C1??
1974 Honda CB 360
06 May 2012 11:23 - 11 May 2012 10:38 #520165 by OneShoe50
Replied by OneShoe50 on topic LED signal stabilizer
Do you leave the diode in with the LED relay? I suspect no, but I want to ask before I install the relay, Thanks.
05/11/12 - Update, used the Lockhart relay, yahoo I have LED turn signals. Now I got to figure out why the the front left signal and the right rear signal blink at the same time..... :silly:
77 KZ1000A1 - Under going a psuedo ELR overhaul
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Sure it looks OK now, but wait until I really make it pretty, with some chrome and paint and some new tires and grips and the wiring. Don't forget the gearing, and the LED's and, and, and....
Last edit: 11 May 2012 10:38 by OneShoe50. Reason: Updated information.
