Lights don't work and plugs won't spark
- kz_fl
25 Feb 2012 20:22
Firstly, I'm an amateur mechanic, so please excuse my sounding ignorant sometimes. I am working on a 1980 kz650. It ran about a year ago, but has been sitting ever since. I just started getting it in shape recently by: cleaning the carbs, changing the spark plugs, putting in fresh gas, changing fuses and buying a battery. I haven't, however, been able to get any of the lights to turn on or the plugs to fire. Is this a normal problem? Any suggestions? My next step is to buy new coils but want, if possible, to find a cheaper alternative. Please help!
1980 kz650
1983 kz1100 LTD
1983 kz1100 LTD
Re: Lights don't work and plugs won't spark
25 Feb 2012 20:43
Time to get the ole meter out and start tracing power problem. Start at the battery to fuses then work your way out. Are you sure your battery ground cable is tight at both ends? Ed
- MFolks
25 Feb 2012 20:45
I'd check the fuses before opening up any switches or wiring harness.
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by using a multimeter to check for voltage going through the fuse, or when the fuse is removed for physical inspection for tight end caps & continuity checks,can it be determined if it’s serviceable.
5. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
6. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
7. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
8. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net/store/6!way-fuse-blocks/p_10822.a_1
www.easternbeaver.com/Main/Elec__Product...ers/fuseholders.html
www.autowiringsolutions.com/item.php?item_id=251&category_id=89 (ATO/ATC Fuse Holder)
9. A source for the glass tubed AGX fuses:
www.boatownerswarehouse.com/browse.cfm/2,4986.html
www.napaonline.com/Catalog/Result.aspx?N...&D=AGX&Dk=1&Dp=3&N=0
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs(your primary wiring may be different).
The 550’s, 650’s, 700’s & 750’s are backwards to what is listed for the bigger 4’s.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod. Your primary wiring may have a different color.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together, so it makes no difference which is used, as long as the correct coil to sparkplug configuration is followed.
The sparkplug caps should read 5K OHMS(5000), any higher, or a reading of infinity means new caps should be ordered.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s, 650‘s,700’s, and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
An indication of black and sooty sparkplugs may not mean a carb or carbs are in need of cleaning, but may mean the input voltage is low.
When checking the input voltage to the ignition coils, first have a fully charged battery, and the using a multimeter, set it up to measure VDC(Volts, Direct Current), range of 20.
Put the RED probe from the multimeter on the same terminal that either a RED wire or ones that’s RED with YELLOW stripe, and the BLACK probe on either a good frame/Earth ground or the battery Negative(-) terminal/post.
Depending on the motorcycles current draw( lighting, and other high amp needs) the reading might be 10 volts or more, but if the reading is down around 8 volts or less, this indicates a corrosion or wiring problem needs correcting to improve input voltage to the coils.
These engines have what is known as a “Wasted Spark” that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
The following user(s) said Thank You: DaddyJama, kz_fl
- jonnybravo
- Banned
25 Feb 2012 20:46
first double check ur fuses using a meter
- MFolks
25 Feb 2012 20:48
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
On some of the older Kawasaki's, the soldered connections inside the switch housings may be crumbling, making for no spark or lights, so check there after looking at the fuses.
- kz_fl
01 Mar 2012 01:00
Update:
Ok, so I started to check all my wires and connections. I have a brand new battery. All my wires are pushing about 12v and the fuses are good. I didn't find anything that looked suspect. There was no interruption in power and I cleaned most of the contacts. I even tested the head/tail/turn signal light sockets. All of them tested 12v. This led me to believe, since none of the lights work, that the bulbs had gone bad after sitting in the elements for as long as they had. I bought new bulbs, but still nothing. There's power going directly to the contacts in the light housings, but the bulbs wont light. Is this because I need new flasher fuses(assuming that's what they're called)? Or wouldn't the lights light up but just not blink? This has me perplexed.
1980 kz650
1983 kz1100 LTD
1983 kz1100 LTD
- MFolks
01 Mar 2012 01:43
See if you have 12 volts to the ignition coils with the run/stop switch to "Run" and the ignition swich to "On". The tank will have to come off to access the coils.Put a multimeter to Volts D.C(Volts, Direct Current) range of 20. Place the Red probe where the Red wires go to the coils and the Black probe on either the batteryNegative post, or a good frame ground.
Some of the older Kawasaki's are suffering crumbled solder connections inside the left and right handlebar switch pods.
Repairing Motorcycle Soldered Connections
When repairing soldered wires on motorcycle switches or light bulbs sockets, have the following on hand:
1. A 25 Watt soldering iron or one that the wattage can be adjusted.
2. Rosin core solder.
3. Rosin flux or soldering paste (Never use solder or soldering paste designed for plumbing work, as it contains an acid that will corrode the electrical joint, ruining it).
4. 91% rubbing Alcohol.
5. A cut down ½” paint brush, or acid brush for scrubbing the repaired solder joint.
6. Clean rags or paper towels
7. A damp sponge to keep the soldering iron tip clean.
8. Some “Solder Wick” a braided bare copper wire designed to collect heated excess solder, aiding in joint preperation.
9. Some wooden toothpicks.
10. Small Hemostats or clip on heatsinks.
A. Before soldering, “Tin” the soldering iron tip by plugging it in or turning the iron on, allowing it to get to operating temperature(2-3 minutes).
B. Unroll about 3” of solder from the roll of rosin core solder & then using a clean rag or paper towel moistened with Alcohol, wipe the unrolled solder, removing the finger print oils that will create a poor solder joint.
C. Apply a small amount of solder to the now heated soldering iron tip, wiping the excess off with the wet sponge, keeping a thin layer on the soldering iron.
D. The soldering iron is now ready for use, but before applying the heated tip to a wire, wipe the tip on the damp sponge, this removes any oxidized solder and makes for a much better connection.
E. If the joint to be repaired is grey in color or appears “Crumbled”, apply some rosin soldering paste or flux to the joint with a small toothpick of screwdriver, and then apply the soldering iron tip for a few seconds.
G. The fluxed joint should clean up, allowing for a better connection. If no luck, use the solder wick to remove all traces of the old solder by apply in it between the soldering iron tip and the bad joint.
H. Hemostats and clip on heatsinks will be used to prevent the wire insulation from burning, overheating & pulling away from the connection.
I. Apply a small amount of flux to the joint to be repaired & then a very small duration of heated soldering iron tip & solder.
J. Clean off the repaired joint with the brush & rubbing Alcohol, the newly repaired joint should appear clean and bright, almost as if it were polished, with no voids or holes.
01 Mar 2012 07:37
- baldy110
01 Mar 2012 18:24
Check your ground wires, all of them.
- kz_fl
02 Mar 2012 16:31
Update #2:
Looks like the plugs weren't firing because of a starter lockout switch. I don't know why it's even there, let alone why it was stopping it from firing up. However, I bypassed that switch and the bike turns over and starts and runs like crap for a few seconds before shutting off. There's no exhaust coming out of one of the pipes, so I imagine it's an ignition coil not firing. Is this right? And does anyone know what size coils I need for a 1980 kz650F1?
1980 kz650
1983 kz1100 LTD
1983 kz1100 LTD
02 Mar 2012 18:06kz_fl wrote: Update #2:
Looks like the plugs weren't firing because of a starter lockout switch. I don't know why it's even there, let alone why it was stopping it from firing up. However, I bypassed that switch and the bike turns over and starts .........
The lockout switch is intended to force the rider to pull in the clutch when using the electric starter. This is to prevent the rider from cranking the electric starter while the tranny is in gear. The early Yammy 750's had no lockout, and I saw a guy standing next to his bike push the starter button with the bike in 1st gear and the clutch not pulled in. That brand spanking new bike jumped off the side stand and crunched into the gravel - very amusing. At the time I had no such problem because I was riding a good ole BSA (no electric start). I figured electric starters on bikes would never catch on. :blush: :laugh:
- Old Man Rock
03 Mar 2012 10:32 - 03 Mar 2012 10:33
"The lockout switch is intended to force - ED - to pull in the clutch while STONED"... :whistle:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Mar 2012 10:33 by Old Man Rock.
