Locks on a Z1
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
Locks on a Z1
22 Feb 2012 15:02
#505673
My memory is failing me, easy question for you guys.
Rather than buying a new key for my Z1 (Z1B, but I don't think it matters), I was thinking of getting an ignition that matched the key to my KZ900. That way I'd only have to worry about one motorcycle key. B)
Is there any other locks that would require a re-keying? Steering lock (this one I know for sure). Seat lock? [I don't think there's a seat lock, I remember just a little lever you'd twist to open the seat] Helmet lock? There are some pieces missing from my Z1 and I honestly cannot remember.
Thanks!
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • etbike3135
  • etbike3135's Avatar
Re: Locks on a Z1
22 Feb 2012 18:27
#505688
There is supposed to be a seat lock that you can use or not. BAck then they gave you the option. It should be located underneath the lever.
1973 Kawasaki Z1
18 years in dragbikes
  • mtbspeedfreak
Re: Locks on a Z1
22 Feb 2012 20:15
#505702
etbike3135 wrote: There is supposed to be a seat lock that you can use or not. BAck then they gave you the option. It should be located underneath the lever.
I will check this out when I get home tonight. Can the steering lock (the one up underneath the lower triple tree) be rekeyed by a locksmith?
2000 ZRX 1100
  • mtbspeedfreak
Re: Locks on a Z1
23 Feb 2012 03:45
#505850
Yes there is indeed a lock under the lever. Thanks!
2000 ZRX 1100
  • badrhino
  • badrhino's Avatar
Re: Locks on a Z1
23 Feb 2012 14:01
#505916
where does one get a seat lock or lever? I don't have one on my bike to hold that side of the seat down.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • mtbspeedfreak
Re: Locks on a Z1
23 Feb 2012 14:37
#505932
badrhino wrote: where does one get a seat lock or lever? I don't have one on my bike to hold that side of the seat down.
I'm talking about a '73-'75 Z1s. Starting in '76, Kawasaki started locking their seats- I don't know when they discontinued doing so, if they discontinued doing so.
2000 ZRX 1100
  • badrhino
  • badrhino's Avatar
Re: Locks on a Z1
23 Feb 2012 15:39
#505942
oh, well either way I don't have a lock or anything to secure the seat on that side. :blink:
Franken Z!
