malfunctioning Dyna S when showers!
- martijn
26 May 2006 12:52
Today I was going to visit a campsite to have a good time with other Kawasaki club members. Unfortunatly my Z650 fitted with a Dyna S was doing a bad job during 3 hours of rain fog en heavy showers. The engine started running several times on 2 or 3 cilinders, especially whe cars made a lot of "spray". This was something NEVER happend with the contact breakers.So I had to return home. I only switches the ignition plates.
What is your solution or what is the problem in this case??
- z1rkrazy
Re: malfunctioning Dyna S when showers!
26 May 2006 13:52
My first suggestion would be to check your point cover gasket. I've had a Dyna S on my Z1R for 3 years and haven't had a single problem with it. Good luck. Ride safe...........
- The Milkman
26 May 2006 14:06
Put some water in a windex type sprayer bottle and direct the spray onto the plug wires and boots with the bike running. I bet you will find the problem.
Ride safe,
Les
Ride safe,
Les
- wireman
26 May 2006 14:59
dont take your bike in the shower with you!:S :woohoo: yeah,i know shut up wireman!:woohoo: :woohoo: :woohoo: :woohoo:
- bill_wilcox100
26 May 2006 15:43
A long shot... no my 1977 KZ650-B1 there is a very small breather hole at the bottom of the breaker cover. Check that it is unobstructed. This is where condensation and or seepage water should drain out. Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- martijn
27 May 2006 13:53
My wife does not let me to take the 650 under the shower ( I did with the Z900 head to clean it). I think I try the spray gun with compressor. Could it be possible that the Dyna's give such a higher voltage that the wires wil leak earlier???
Cheers
martijn
Cheers
martijn
- rstnick
28 May 2006 05:24
What front fender do you have on there? I tried a shorter LTD fender on my bike, and when it rained, I got water spray up under my gas tank soaking the coils. My engine started dying slowly, then all together. Took the tank off and the coils were dripping with water. Toweled them off, and she started right up. I'm now using the longer stock fender again, plus I sprayed electrical Igniton sealer on all the electrics and coils.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- martijn
28 May 2006 13:20
I do have a long fender on it, but I suppose that fog/moist which is created by cars driving in front will give the same problem. ( at least what I noticed).
- Sandy
- Fly High,Tony
28 May 2006 14:22
The Warden and I(and Tony,on His bike) were out last weekend,and We all got caught in the rain for about 20 miles at highway speeds,and no problems with My Dyna2000 at all.
(which reminds Me...I still haven't cleaned the bike off,lol...gotta go!):lol:
1977 KZ1000 A-1
- martijn
04 Aug 2006 12:34
Still problems!! We went on a 4 day trip with some really heavy showers wenn the xxxxthing started running on 3 or even 2 cilinders. I was in good company because a KZ1000 from 1978 had exactly the same problems. We had to wait for about 2 hours before we good ride off...
- N0NB
- Blue handles better
04 Aug 2006 13:20
How new are your plug wires, coils and plug caps? I suspect that the problem exists between the coils and the plugs. Any small crack in the wire or coil housing will allow a short circuit and the high voltage of the secondary will find this quicker than the low voltage DC from the Dyna/breaker points to the coils.
HTH,
- Nate >>
HTH,
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- wiredgeorge
04 Aug 2006 13:45
When a coil cracks, it tends to short when it rains. I have a set of very cracked Dyna coils that did the same thing when it was damp out and fixed them with epoxy. They work fine now.
