- Thank you received: 2
malfunctioning Dyna S when showers!
- DesertWizardB1
05 Aug 2006 05:36 #67257
by DesertWizardB1
Len
77 KZ 1000 LTD Original Owner
Replied by DesertWizardB1 on topic malfunctioning Dyna S when showers!
Are you by any chance running pods instead of the stock airbox? When I was running pods I would loose the outer two cylinders when it was raining from all the water getting sucked in.
Len
- martijn
- Thank you received: 1
06 Aug 2006 10:59 #67499
by martijn
Replied by martijn on topic malfunctioning Dyna S when showers!
I'm using pods, but my KZ1000 friend has an original KZ1000 execpt for the Dyna S ignition, coils and high tension leads.
The stupid thing is that it started to behave bad when II replaced the breaker points for the dyna. I think I'll swop the leads and coils again and try to catch some rain...
- baldy110
- Thank you received: 512
06 Aug 2006 12:07 #67512
by baldy110
Replied by baldy110 on topic malfunctioning Dyna S when showers!
Spray some WD-40 all over the Dyna S pickup under the points cover and make sure the gssket is good.
