What is this wire to?
  • ramtough_63
  • ramtough_63's Avatar Topic Author
28 Jan 2012 15:50
#500475
with my counter sprocket cover off I notice this wire hanging
and for the life of me dont know where it goes
I looked through the book but couldnt seem to locate it
Attachment 100_2451.JPG not found
Attachment 100_2452.JPG not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • loudhvx
  • loudhvx's Avatar
Re: What is this wire to?
28 Jan 2012 15:57
#500478
Oil pressure or neutral switch. You'll have to clean it a little to determine the color.
Blue/red or green/orange. But it's probably tarnished brown/yellow from oil and heat.
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
28 Jan 2012 16:35 - 28 Jan 2012 16:37
#500485
Oil pressure switch should be up behind the cylinders. Only thing I can think of is the neutral switch. Do you get a neutral light? Have you tried grounding it to see if a light comes on? Neutral switch is Lt Blue/Red. Go to Filebase up in the right hand corner of this page and find your year and model and click on the wiring diagram.
If it turns out be a brown wire then it is most likely a ground wire for something, I don't know what though.
Last edit: 28 Jan 2012 16:37 by DiamondSkyBlue1000.
  • loudhvx
  • loudhvx's Avatar
28 Jan 2012 19:04
#500504
If the oil pressure switch is behind the cylinders, then it only leaves neutral, as Diamond said.
According to the diagram in the filebase, neutral is light green/orange, at least that's what the colors appear to be in the PDF, (which is pretty clear).
Brown is usually switched positive. I can't imagine any reason for a switched positive down there. Usually I find most of the wires down there have a brown grimey look to them.
  • ramtough_63
28 Jan 2012 19:35
#500513
it is a (switched) hot wire I dont remember unhooking anything when I took the cover off other than the clutch cable i have to belive its the nuetral switch anyone have a pic of the nuetral switch on a kz1000
i dont know where it is located
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • loudhvx
  • loudhvx's Avatar
28 Jan 2012 20:11 - 28 Jan 2012 20:15
#500521
If it's the neutral wire, then it isn't switched hot.
The neutral wire will appear to behave like a switched hot wire, but it is actually the ground side of the light bulb. Since the ground is lifted, it will appear like a hot wire, but will not provide current like a normal hot wire.
Now that I look closer at the diagram, the neutral wire looks like it may actually be light green with red stripe, instead of orange stripe.
If the wire is truly a switched hot wire, I can't imagine what it would be for.
Here is the wiring diagram, by the way.
www.kzrider.com/filebase/cat_view/97-197...wasaki-kz-1000-a2a2a
Last edit: 28 Jan 2012 20:15 by loudhvx.
  • ramtough_63
28 Jan 2012 20:14
#500522
loudhvx wrote: If it's the neutral wire, then it isn't switched hot.
That makes sense I am pretty sure it is the nuetral wire
My next question is where does it go lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • etbike3135
  • etbike3135's Avatar
28 Jan 2012 20:17
#500524
Where that big green bolt is! Somebody took your switch out and replaced it with a bolt.
1973 Kawasaki Z1
18 years in dragbikes
  • loudhvx
  • loudhvx's Avatar
28 Jan 2012 20:19
#500525
I hate those thieving neutral-switch thieves! :angry:
  • ramtough_63
28 Jan 2012 20:31
#500529
Nothing worse than a nuetral switch thief!
Thats some funny shiz my nuetral lite always had a mind of its own now I know why!
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • gengomerpyle
  • gengomerpyle's Avatar
28 Jan 2012 20:35
#500531
etbike3135 wrote: Where that big green bolt is! Somebody took your switch out and replaced it with a bolt.
what he said ^^^^^^^^^^^^^^^^^^^^
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • ramtough_63
28 Jan 2012 20:46
#500536
ordering one now thanks guys
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
