ideas for mounting switches
- Topper
09 Jan 2012 23:18
I'm looking for some ideas about how/where to mount an auxiliary switch or two. This is for a '79 KZ750 but I'd be interested in seeing just about anything.
Got some ideas for me?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- ramtough_63
Re: ideas for mounting switches
09 Jan 2012 23:56
I have been toying with the idea of police bike controls gives you extra switches not sur how the internals are but i am sure can be adapted if not a direct wire. the siren and auxillary lights are made in.
but adding extra quote togel switches, havent seen any i liked yet
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- MFolks
10 Jan 2012 00:15
If there's space on the handlebars, some of the rubber insulated cable clamps that fit the bars, might be able to hold/mount an Aluminum plate for the switch or switches to install in.
Something like this:
www.alliedelec.com/search/productdetail.aspx?SKU=70182295
- Topper
10 Jan 2012 08:37
The cable clamps are a pretty good idea. I don't know about a plate though. That'll leave the back of the switches exposed. Maybe I could mount a small project box that way.
Got any pics of the police controls?
1979 KZ750 Twin
1979 KZ750 Twin
- MFolks
10 Jan 2012 15:16
If you use vapor resistant Mil-Spec switches, the only exposure will be at the terminal connections as the rest of the switch is protected.
MS24523-22 SPST Toggle Switch
www.alliedelec.com/search/productdetail.aspx?SKU=6422180
MS24523-23 SPDT Toggle Switch
www.bpbsurplus.com/lc/cart.php?target=pr...7468&category_id=325
MS24523-28 SPST Toggle Switch Momentary
www.bpbsurplus.com/lc/cart.php?target=pr...8139&category_id=325
MS24524-22 DPST Toggle Switch
www.prowireusa.com/prodinfo.asp?number=MS24524-22
www.gadgetjq.com/accessory_switches.htm
If possible, do not solder any switch connections,as the solder will "Wick" up inside the wire insulation, making it prone to break from vibration. It's btter to crimp on terminal ends using the correct tools:
www.pbase.com/mainecruising/wire_termination
(The Good, Bad, & Ugly Wire Crimpers)
- Topper
10 Jan 2012 16:14MFolks wrote: If you use vapor resistant Mil-Spec switches, the only exposure will be at the terminal connections as the rest of the switch is protected.
Is it OK to have that exposure at the terminal? Seems like that would be a bad idea.
1979 KZ750 Twin
1979 KZ750 Twin
- DoubleDub
10 Jan 2012 16:47
You can use a heat shrink tube to protect the terminal. Use a lighter or a heat gun on low and it shrinks up and protects the connection.
en.wikipedia.org/wiki/Heat-shrink_tubing
- DoubleDub
10 Jan 2012 16:49
Or use some dielectric grease on the terminals like on a battery. Those mil-spec switches shouldn't give you an issue with exposure, but you want to protect them from shorting against the bars or each other.
- mark1122
- Keep twisting it
10 Jan 2012 18:41
there should be a few bikes out there with extra buttons on the controls to choose from. i know my buddies triumph (sold in canada) has an extra button on the left side. its some sort of a hi beem passing thing that is common in europe i think. also, some bikes have an emergancy flasher button.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- MFolks
10 Jan 2012 18:58
You could overcoat the electrical terminals with clear or black silicone sealant, protecting them away from moisture, but still allow esay removal. Just don't use the adhesive/sealant type as it sets up almost permanent.
Another place to mount the switch or switches, would be to drill & tap the handlebar clamps for 10-32 threads and then use spacers between the switch mounting plate for installation(allow for switch and wiring clearances).
www.smallparts.com/hsta-10-24-anodized-a...f_=goo_pf_B000GOMJPY Use a 10-32 long setscrew with #262 RED Loctite as a male part to thread into the threaded spacer.
www.keyelco.com/products/specs/threaded%20standoffs-10-32.asp
- Topper
10 Jan 2012 19:00DoubleDub wrote: You can use a heat shrink tube to protect the terminal. Use a lighter or a heat gun on low and it shrinks up and protects the connection.
Oh I'm familiar with heat shrink tubing. It just doesn't look like it would cover several of the terminals in the switches recommended. I think I've struck on an idea though. I've seen some stuff at the hardware store that is "liquid electrical tape". You paint it on like nail polish. I bet that would work.
1979 KZ750 Twin
1979 KZ750 Twin
- djturnz
16 Jan 2012 12:58
Some Flush mount rockers would fit in your side panels (as long as you don't mind drilling holes in them). Some of the chopper guys like clean bars, so they mount a 3-way toggle switch in the back of the headlight bucket to run their lights. So that is a spot for an extra switch.
What are you adding? Oil slick? Machine guns? Ejector seat? NEON?
1982 KZ750 (4) LTD
