dayna ignition
Re: dayna ignition
26 Dec 2011 18:58 - 26 Dec 2011 19:00
#494757
Here's what's happening.
Battery positive connects to an ignition coil's primary terminal, and passes through the coil's internal primary winding which ends at the coil's other primary terminal, where a wire runs to a Dyna-S module and reaches ground through the module, whereby the coil "charges."
When the rotor's embedded magnet passes by the module, the coil's ground connection through the module is interrupted (lost), which causes the coil to fire through both spark plug wires.
After the magnet has gone on past the module, the coil is again grounded through the module, and is again "charged," until the magnet again passes by the module.
Points work the same way, where "closed" provides coil ground (charges), and "open" un-grounds the coil (fires).
Good Fortune! :)
Last edit: 26 Dec 2011 19:00 by Patton.
  • SCHWACKS
  • SCHWACKS's Avatar Topic Author
Re: dayna ignition
26 Dec 2011 20:12
#494763
i really aprecciate the help, a lot. Thank you! coming off each coil are two wires. one yellow and one black, which wire goes to the ignition. the yellow or the black?
Re: dayna ignition
27 Dec 2011 01:02
#494794
SCHWACKS wrote: i really aprecciate the help, a lot. Thank you! coming off each coil are two wires. one yellow and one black, which wire goes to the ignition. the yellow or the black?
On each coil, one of the two wires is feeding switched battery positive to the coil, and the other wire goes to the ignition.
Good Fortune! :)
  • Old Man Rock
  • Old Man Rock's Avatar
Re: dayna ignition
27 Dec 2011 08:29 - 27 Dec 2011 08:42
#494821
Regardless of the color coding all you have to do is follow from the pickups themselves in determining which one goes where.
Example: See attached drawing.
The pickup-sensor on the left is for coil 1/4.
The pickup-sensor on the right is for coil 2/3.
Each pick up will have a red conductor attached to one end for switched battery voltage (after ignition switched to ON position).
Whatever conductor color the left pickup has attached goes to the coil used for 1/4 pistons.
While the other conductor attached to the right sensor goes to coil used for 2/3 pistons.
Maybe this will help...
Attachment DynaSBenchTest.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 27 Dec 2011 08:42 by Old Man Rock.
  • SCHWACKS
Re: dayna ignition
27 Dec 2011 09:24
#494825
F yeah! Thank you Old Man Rock and thank you for the added in coloring of wires. Patton, you guys both rock. Thank you so much! With out this site there would be a lot of Kaws out there spittin and sputterin.
