surprise, i was about to install a Dyna S and ..
  • Motor Head
  • Motor Head's Avatar
Re: surprise, i was about to install a Dyna S and ..
08 Nov 2011 22:09
#487694
Back about the Dodge OMNI/ Plymouth HORIZON-K Car days. With the Progressive Holley.
  • bountyhunter
  • bountyhunter's Avatar
08 Nov 2011 22:40
#487702
loudhvx wrote: And by the way... none of the above ignitions are CDI. CDI was used on the two-stroke Kaws, but not on the KZ's. All of the above are transistorized Kettering ignitions.
Yeah, it seems that "CDI" is now the generic name for any electronic ignition.
  • supereightmm
  • supereightmm's Avatar Topic Author
09 Nov 2011 07:35
#487751
Hello , back on spanish time here , thanks for all the replies , yes i dont know why i keep on calling it CDI , i have more expirience on 2 stroke morotcycles than with this ;) .
ok i found out a but more , the ignition kit is called Lucas Rita , its basically made for britt bikes , here are some more pics , the wiring is quite messy and i dont like it at all so ... since i have a brand new dyna s , i pressume ill be fine if i follow this steps , please correct me if i say something crazy ..
remove the "Alien " pick up
remove the coils
remove the ingiter module ( huge box btw )
remove the diodes ( attached to the coil)
clean up the wires and rewire as per the original diagram ( i have one )
install the DYNA S and the 2 green coils also from Dyna
am i missing anything ?
this is what i have on the bike ..
www.britcycle.com/Products/images/333113inst.pdf
Attachment IMG_2021_2.jpg not found
Attachment IMG_2022_2.jpg not found
Attachment IMG_2023_2.jpg not found
Attachment IMG_2024_2.jpg not found
Attachment IMG_2025_2.jpg not found
Attachment electronic1gnition.JPG not found
09 Nov 2011 08:33
#487753
Lucas - because a gentleman shouldn't be motoring about after dark anyway. :laugh:
  • JR
  • JR's Avatar
09 Nov 2011 12:41
#487765
650ed wrote: Lucas - because a gentleman shouldn't be motoring about after dark anyway. :laugh:
hahahahaha
Lucas also known as Prince of Darkness with good reason :laugh:
  • loudhvx
  • loudhvx's Avatar
09 Nov 2011 12:57 - 09 Nov 2011 13:16
#487768
It fires both coils, which means all four cylinders, at the same time, always. That's a pretty wasteful design (in terms of power) for a 4 cylinder. But, as you suggested, if you grind one point of the rotor down, it would be ideal for a 360 degree twin, like the KZ750 twin, or KZ400 twin. You can get rid of the big diodes that way too (they are only there because coils don't like to run in parallel). It seems like a poor design. All it takes is for one of those diodes to pop, and there you are, stuck on the side of the road.
Last edit: 09 Nov 2011 13:16 by loudhvx.
  • bountyhunter
09 Nov 2011 16:11
#487784
I heard that Dracula and Lucas got into a real knock down fight in a pub one night over who had the more legitimate claim to the title "The Prince of Darkness".
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
09 Nov 2011 16:22
#487786
supereightmm wrote: remove the "Alien " pick up
remove the coils
That will be all you need (for the ignition anyway). The Dyna-S with the 3-ohm coils is a complete ignition system (minus plug wires and plugs of course). It may be a little tricky to mount the green coils. On my 750, I had to use some generic L brackets to get them on without hitting the tank. It should be a fairly simple install, though I caution you to make sure the wires from the Dyna-S are secured OFF the exhaust/mufflers. I just realized I hadn't done this yesterday when I kept blowing ignition fuses! :blink:
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
  • clutch
  • clutch's Avatar
09 Nov 2011 16:31 - 09 Nov 2011 16:32
#487787
There is no way to properly set the timing with this set up. The timing "window" (big hole), should be at 12 o'clock. This is almost certainly a homemade setup!
EDIT: or is the pic sideways? LOL!
Wish List:
Z1 (need I...
Last edit: 09 Nov 2011 16:32 by clutch.
  • loudhvx
  • loudhvx's Avatar
09 Nov 2011 16:35
#487788
Sideways. Note the bulge on the right side of the casting in the photo. That is the bottom.
  • clutch
  • clutch's Avatar
09 Nov 2011 16:36
#487789
Whoops! Silly me... LOL!
Wish List:
Z1 (need I...
  • Kawboy74
  • Kawboy74's Avatar
10 Nov 2011 23:06
#487974
Bin the stuff and use the Dyna as you planned. I remember changing ballast resistors on Chrysler products back in the day and it was always when you really needed your vehicle that it crapped out. Got to carrying an extra in the glove box but always got dirty when going out somewhere! By the way, ever wondered why the English drink warm beer? Lucas made the electrics for their refrigerators!
Good luck! David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
