AGM Battery, Any Good Tricks to revive one?
  • Motor Head
  • Motor Head's Avatar Topic Author
16 Oct 2011 10:46
#483500
Well this AGM Battery I got with the Concours doesn't want to get a deep charge. It has no Amperage storage capacity. Goes down overnight with a .7 amp draw from the digital clock, higher than I would like. I've tried a slow trickle for like 3 days before I even used it once. Then I've tried fast charging at 10amps rate for an hour then back to the trickle overnight. Still no good, battery had sat dead for at least a year. But was new and was probably not used much at all. Seems like it gets a voltage level of 13 or so after charging, then after taking the surface charge off it drops down to 11.5v, I think it may just be F'd.
Using the Wet Acid out of the KZ now, and am going to get another Wet unless someone can convince me that the AGM can be rescued. Do they get a Memory in them like some Ni-cads? Thinking of pulling it to Zero/ Dead and trying to revive it again.
Thoughts?
  • loudhvx
  • loudhvx's Avatar
Re: AGM Battery, Any Good Tricks to revive one?
16 Oct 2011 11:18 - 16 Oct 2011 11:21
#483506
A friend of mine went through several brands of AGM batteries, and he said the only one that he recommends is the one from BatteryStuff.com. He had problems keeping a charge on the other brands. He had to toss them.
I bought one from there (BatteryStuff.com) in the spring and so far it works as well as any normal flooded battery. But I don't have any devices permanently drawing a trickle from the battery.
Are you sure it's .7 Amp? That's a huge amount for a clock... like 8 watts. Maybe you mean .7 mA?
Based on the 11.5v shortly after charging, I'd say it's belly up. It should stay up over 12v, (after the initial drop from 13v), after charging.
Last edit: 16 Oct 2011 11:21 by loudhvx.
  • Old Man Rock
  • Old Man Rock's Avatar
16 Oct 2011 11:19
#483507
Why take the chance even if you could get it somewhat revived... Junk it...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Motor Head
16 Oct 2011 11:49 - 16 Oct 2011 12:13
#483512
The draw is .7 amp, I wish it was like 20ma. I just got this Clock with the used gauges, and it works well. The other old one has a messed up Set button for the Minutes. I may use the spot in the console to put in something more useful, like a Volt meter. Clocks I really don't care WTF time it is!
:laugh:
Junk it is what I'm doing, just seeing if I'm missing a process with it. I've done what I though was going to have a chance of using it. My experience has been with normal wet cells and not the AGM. But nothing worse than letting a battery sit and discharging.
Its an Interstate Product line battery.
www.interstatebatteries.com/cs_eStore/Pr...II+-+270+CCA+-+18+AH
Last edit: 16 Oct 2011 12:13 by Motor Head.
  • loudhvx
  • loudhvx's Avatar
16 Oct 2011 12:13 - 16 Oct 2011 12:15
#483518
Yikes. :ohmy:
0.7 amp is more than a standard 1157 tail light bulb. That's like leaving the tail light on 24/7. That will easily discharge a battery overnight to the point of not starting. Then recharging it will be a deep cycle. I wouldn't expect a battery to last more than a few weeks that way.
Time to ditch the clock.
Last edit: 16 Oct 2011 12:15 by loudhvx.
  • Motor Head
16 Oct 2011 12:21
#483519
That's right, so I've had the float charger on it at night. Less than 50ma is what I've always looked for on draw. Clock is coming off line, and then probably a voltmeter instead. The regular wet battery from Napa I've taken from the KZ, starts it right up after 1 night, no problem. But that draw is out of spec. Loose the clock I say.
And the AGM, reading 10.4 after knocking the surface charge off, has a 4 amp head light hooked up to it monitoring the time it takes to drop voltage. I saw a chart on the net before on deep cycle batteries and Amp hour rating and discharge rate. It takes almost no effort to see what it does. It can discharge while I fix some of the remaining broken plastic. :P
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
16 Oct 2011 13:42
#483527
I don't think that draw rate for the clock is right if it is more than a bulb. On mine the clock wouldn't drain the battery even when it sat for a month in the early spring waiting for another good day to ride it. It has an illumination bulb in it that should be on unless the bike is on, that might be the source of the drain. The clock is an LED setup so it won't draw squat really.
As for AGM's they are either good or junk, horrible creatures for taking a charge and indicating full capacity then as soon as you put a heavy load on them to say start the bike then they tank out. Before junking I'd full charge it on the bench then wait a day or so and put it back in to try it. If it is flat or tanks then trash it, if not then you probably have a wiring gremlin.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • Motor Head
16 Oct 2011 14:08
#483530
I dropped it down to 2.4v using 2 headlights. Following the Label on the top for charging rates, I have it on Quick 10amps for 1 hour timer. Then I'll finish it with a 2amp for 4 more hours. Then I'll retest, got plenty of spare time today for puttering around in the garage.
  • bountyhunter
  • bountyhunter's Avatar
16 Oct 2011 15:05
#483534
Motor Head wrote: Well this AGM Battery I got with the Concours doesn't want to get a deep charge. It has no Amperage storage capacity. Goes down overnight with a .7 amp draw from the digital clock, higher than I would like. I've tried a slow trickle for like 3 days before I even used it once. Then I've tried fast charging at 10amps rate for an hour then back to the trickle overnight. Still no good, battery had sat dead for at least a year. But was new and was probably not used much at all. Seems like it gets a voltage level of 13 or so after charging, then after taking the surface charge off it drops down to 11.5v, I think it may just be F'd.
Thoughts?
It's sulphated internally. RIP battery.
  • bountyhunter
16 Oct 2011 15:07
#483535
Motor Head wrote: The draw is .7 amp, I wish it was like 20ma.
That will killl most bike batteries in about 15 hours. Disconnect it.
  • bountyhunter
16 Oct 2011 15:08
#483536
loudhvx wrote: Yikes. :ohmy:
+1. Deep cycling lead acid batteries kills them QUICKLY.
  • ramtough_63
  • ramtough_63's Avatar
16 Oct 2011 16:31
#483546
gotta deal on a new Deca AGM didnt survive long enough to get my bike running. blamed the charging system 3 months old ended up with a batteries now AGM fires everytime I hit the Button. Bike sits about a week between rides sometimes 2. without a tender I am inclined to believe Some of em are junk right out of the box.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
