KZ1000P 1996 Schematic??
  • kcornell6
  • kcornell6's Avatar Topic Author
06 Oct 2011 15:22
#481726
Hey all,
Working on a bobber project found HERE .
I'm trying to sort through the wiring, and its a big Charlie Foxtrot. The cops really knew how to get alot of accesories on there with random wires. I don't have a manual or schematic, and don't want to go cutting wires untill I cut the wrong one out.
Does anyone have schematics of manual for 94-00 version of the Police model? Would go a long way.
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
  • MFolks
  • MFolks's Avatar
Re: KZ1000P 1996 Schematic??
06 Oct 2011 16:39
#481734
Would this work? www.cyclepsycho.com/kz1000p/kz1000p.html I don't think the wiring changed much from year to year.
  • MFolks
  • MFolks's Avatar
06 Oct 2011 16:42
#481735
And this is for the basic lighting color codes:
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
  • kcornell6
06 Oct 2011 17:14
#481739
Any bit helps. Thanks much Folks.
V/R
Kev
P.S-Interested why you have a Phantom as a Avatar...??
96' KZ1000P Bobbed
81 GS850L
  • MFolks
  • MFolks's Avatar
06 Oct 2011 19:12
#481755
I was in the USAF for eight years,loved the sound of the twin J-79's on the trim pad and on the flight lines at the many bases I was at.
  • kcornell6
06 Oct 2011 19:45
#481765
hua,
Current AFROTC
96' KZ1000P Bobbed
81 GS850L
  • MFolks
  • MFolks's Avatar
06 Oct 2011 19:55
#481767
Thinking about the Air Force Academy? I was an Aircraft Weapons Mechanic,maintained/repaired weapons release systems on some (for you, old aircraft),F-105 B,D,F & G,F-106 A & B,A-37B , UH-1N gunship, and the F-4C,D,E, & G models.
Helped me perfect electrical troubleshoting, working on so many types of aircraft.
