- Thank you received: 6
How to make tach work on FrankenZ ?!
- badrhino
27 Sep 2011 01:05 #479868
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
How to make tach work on FrankenZ ?! was created by badrhino
Sooo I have a 1980 KZ1000 with a J motor with 1100 heads on it. :blink: :silly: :whistle: :woohoo: I know....wtf? Right? LOL
So How can I go about getting a tach to work on this bike. I believe it has the original tach and correct me if I'm wrong but those are mechanical tachs and the J mtor/1100 heads need electronic tach. What do I have to do get a J model tach or is there another way?
Franken Z!
- Motor Head
- Thank you received: 391
27 Sep 2011 01:13 #479870
by Motor Head
Replied by Motor Head on topic How to make tach work on FrankenZ ?!
No tach drive hole in the head, otherwise you could've put the CSR cam in with a drive. But electric would be the way to go. The LTD and the Sport touring A1&2 had the electric tach and speedo. If you want dimensions and pictures I could get that in the morning for you. That would give you a bit on the mounting, which I know is different than the Mechanical, and what warning lights are there and what it looks like. It has the right turn, High beam Indicator and the headlamp warning in the tach.
- badrhino
27 Sep 2011 01:20 - 27 Sep 2011 01:22 #479872
by badrhino
Franken Z!
Replied by badrhino on topic How to make tach work on FrankenZ ?!
Yeah I searched on e-bay and looked at a few. I just don't think a newer tach would look right on there as the older ones were a little bit longer and shaped different. I love the looks of the older style ones. Crap!
Franken Z!
Last edit: 27 Sep 2011 01:22 by badrhino.
- Motor Head
27 Sep 2011 01:23 #479873
by Motor Head
You could open one of the old ones and put the electric in the early housing. Could get an aftermarket thats close as well, maybe. Aftermarket juts in the early housing. Several options, like ordering off of a menu. :laugh:
- wireman
- Thank you received: 299
27 Sep 2011 01:27 #479875
by wireman
Replied by wireman on topic How to make tach work on FrankenZ ?!
im sure ive had a couple of the newer style heads with tach drive on them,just cant remember model they came from maybe csr?
anyway what about just leaving your tach on there just for looks and mounting a shift light on there between your gauges to tell ya when to shift?
- badrhino
27 Sep 2011 01:35 #479876
by badrhino
Franken Z!
Shift light could be a possibility, but replacing internals with electronic ones would also be sweat.
Franken Z!
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
27 Sep 2011 03:12 #479886
by clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Replied by clutch on topic How to make tach work on FrankenZ ?!
Not sure if you're looking to update, but when I had issues with my tach and speedo a while back, I upgraded to an Acewell computer. This picks up tach signal off of your pickup wire to the coils, also has speedo, odometer, 2 tripometers, plenty of extra goodies, and all the indicator lights. I love mine!
~Clutch
~Clutch
Wish List:
Z1 (need I...
- jms3257
27 Sep 2011 10:01 #479911
by jms3257
1980 KZ1000 LTD
Been away from riding for way too long, enjoying the journey back.
Replied by jms3257 on topic How to make tach work on FrankenZ ?!
I saw someplace a replacement Tack that is electronic, no cable, looks like original. Try looking at Redline. Was considering getting one for mine.
Jim:
Jim:
1980 KZ1000 LTD
