- Thank you received: 391
KZ750 Twin Won't Start, STILL wont start!! Updated
- Motor Head
29 Sep 2011 22:29 - 29 Sep 2011 22:33 #480512
by Motor Head
Steele you had this on the first post, Pin to lock in place the Sun Gear.
Its probably you're avatar causing the distraction!! :whistle:
Replied by Motor Head on topic KZ750 Twin Won't Start
steell wrote: Inside the nose of the starter is a planetary gear set used as a gear reduction. It sounds like the ring gear on that gear set is spinning, but it's supposed to be locked to the case.
Last edit: 29 Sep 2011 22:33 by Motor Head.
- TZ750
21 Sep 2019 15:04 #811152
by TZ750
Replied by TZ750 on topic KZ750 Twin Won't Start, STILL wont start!! Updated
This website has a Motorcycle Starter & Repair Kit Application Guide:
www.nationsautoelectric.com/motorcycle.html
www.nationsautoelectric.com/motorcycleapplication.html
PART # YEAR DESCRIPTION MFG. ID# ROTATION #TEETH PART # SET HOLDER
KS-15 1976-UP KZ 750B MIT SM-224 CW 31 RBK-33 B-5 GL
