- Thank you received: 17
KZ750 Twin Won't Start, STILL wont start!! Updated
- gengomerpyle
750steve wrote: Also, the 2nd pic in this advert;
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem...trksid=p5197.c0.m619
& the pic in this advert are the same.
..........the reason i went for the 1st one is the $20 difference in shipping to the UK
They could all possible be the same internals instead of making different ones? I dunno, just guessing but it does say in the list it will fit my bike. I do see your point though.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- 750steve
Rebuild kit on its way now though so i might as well do it when it arrives. I have no idea what the broken piece was that i took out earlier as mentioned.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- 750steve
*EDIT* After having more knowledge on completion of this thread & anyone is reading this that is going through a similar situation DO NOT throw this small piece of metal out like i nearly did..........read on to see why!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- 750steve
Steve, the planetary gear you're talking about, it's the larger 1 right?, the armeture nose (spelling??) connects with 2 small gears which spin against the outer gear. Is it this large outer gear that should be connected to the outer case? If it is i cant see how it is fixed to it, do i use a threadlock or bearing seal or something? It seems to be grooved to sit in a 'cup' with some lugs on it, but the large gear spins?
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
- Thank you received: 391
- 750steve
Im not sure of what you want me to show in the pic you're asking for, the armature (the bit that spins inside the starter to drive the planet gears) nose goes into the planet gears & spins them, this in turn spins the final output nose where the chain rides, when the resistance is too much i believe the sun gear is spinning instead of the output nose where the chain rides.
What i dont know is how to stop the sun gear moving & i cant see how it can be 'fixed' to the outer casing??
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
Wouldn't you say that if the Sun was held in place that the drive force would be transferred to the output? As this Sun and Planets are just reduction gears for the high compression of the bigger twin cylinders. I wonder if it could be welded in place?
Not uncommon to upgrade to a reduction starter on a High compression street machine.
- 750steve
What is the reduction starter upgrade you mention? I've never heard of it.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
If it could be welded, it would have to be in the correct position or biding of the gear set would occur. Repressing, well maybe if the outside of the Sun and the Inside of the End Housing were Knurled. Then a Locking agent such as The Red Stud and Bearing Mount From Lock-tite was applied.
If your town has a Rebuilder he might be able to source up the new End Housing with Sun Gear? We have 1 in town, and the guy Knows his stuff, been there a very long time.
Does that Starter Motor Have a Brand and # besides the Kawasaki? Like Nippon Denso or something?
- 750steve
There's no chance of a rebuilder here! It'd be cheaper buying a new motor if i were to post it away to be fixed as well.
Pressing i doubt will work, i dont see how the 2 would 'grip' or mate into each other permanently. I had hoped some kind of locking agent or glue may work but i think thats a tall order with the force it'll be put under.
Welding too will prob not work as the weld wouldn't be 'fine' enough as not to restrict things, it wold also have to be done on the inside of the sun gearing as you look down on it as there is no room between it & the outer casing. If it is welded inside the sun gears will then catch on the weld im sure.
Oh dear!!!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
