Everything Fuses
  • johnskzs
  • johnskzs's Avatar Topic Author
Everything Fuses
01 Sep 2011 16:08
#473534
My husband has a Kaw Z1 900 he totally took apart and rebuilt. He is having an electrical problem and can't seem to find the problem. The only sources of power are battery and fuses. Is this correct? Well, he has installed a new battery and has checked the fuses......should there only be 3 fuses? The fuse box says MAIN ~ HEADLIGHT ~ TAIL LIGHT. Can this be ALL the fuses there is? Thanx for any help.
  • RonKZ650
  • RonKZ650's Avatar
Re: Everything Fuses
01 Sep 2011 19:13
#473579
Yes there are only 3 fuses. Best way to check fuses is with a voltmeter. Turn the key on and check volts on all 3 fuses on both ends and make sure 12v is on all ends of all 3 fuses. Of course 12v on one end and nothing on the other is a bad fuse. Nothing on either end of one means problems prior to the fuse in the wiring, ignition switch and so on.
  • johnskzs
01 Sep 2011 19:29
#473604
Checked fuses and they are fine. Seems the starter relay solenoid isn't right. He took a wire with clips on both ends and clipped one end to positive on battery terminal and other end to starter wire that goes into the selonoid. Engine started to crank. So maybe it needs a new relay solenoid? Where is everyone getting parts for Kawasaki KZ900's? Like who is reliable? I saw a solenoid identical to his but it was for a Suzuki ATV!!! Wonder if someone has put in so strange parts? Thank you RonKZ650! Nice bike!! We have a KZ750 we are trying to get rid of so my husband is kinda stuck on KZ's!!
  • MFolks
  • MFolks's Avatar
01 Sep 2011 19:55
#473612
Starter Solenoid/Motor Checkout Procedure
Some simple steps to determine what is working and what's not:
1.Fully charge and test the battery(most bike shops can load test the battery, and then use a floating ball hydrometer to check specific gravity in the charged cells).
2.Clean all battery terminals of corrosion.
3.Tighten all starting related connections(Positive RED(+) battery terminal, Negative BLACK(-)terminal) and from the terminal to the engine case. All connections must be clean and tight. If the cables feel “Crunchy” when flexed, they may have corrosion inside the insulation, requiring replacement.
4.Clean the cable from the starter solenoid to the starter motor.
5.Clean and check the "bullet connectors" going to the coil side of the starter solenoid.
6.Try again to start the bike, keep in mind some Kawasaki’s have a clutch interlock to prevent cranking the engine while it’s in gear, so the clutch lever must be squeezed.
7.If no luck, go to step #8
8.Wearing eye protection, bridge with pliers or a screwdriver the two heavy duty(large)terminals on the solenoid. If the bike cranks, your solenoid may be bad.
9. If the starter won’t turn over, one of several things has happened; The starter motor has seized due to brushes binding up, lack of lubrication in the bushings of the motor, the battery is weak , the engine has seized or it could be a combination of any of the above. Some websites for starter motor rebuild kits are:
A. www.mawonline.com/newsite/rick_s_motorsp...-starter_brushes.htm
B. www.psep.biz/store/mitsuba_starter_motors_page_2.htm
10.The dealer may want $$$ for a new solenoid, but take your old one along and visit the nearest riding lawn mower shop. They have solenoids for about $15 that with a little work will fit. Be aware that the new solenoid from the lawn mower shop may require a ground wire for it to work.
11. I’d recommend upgrading from the existing battery cables to at least 6 gauge welding cables.
They are available in two colors(RED and BLACK) have more flexibility due to being constructed with finer conductors, and will fit in tighter areas.
12. The welding cable is sold by the foot, so take careful measurements or bring your old cables along. Most battery shops might be able to supply the cable too, so call to find out. The battery shop should be able to crimp/swage on the end of the welding cable the terminal ends or lugs using either a dedicated crimping machine or a tool that looks like a bolt cutter that has special dies to terminate the cable.
01 Sep 2011 22:02
#473634
johnskzs wrote: ...Where is everyone getting parts for Kawasaki KZ900's? Like who is reliable?....
Z1 Enterprises is one of the best sources for parts at reasonable prices. :cheer:
And no better service on the planet.
www.z1enterprises.com/
Good Fortune! :)
