Bad rectifier... whats the chances the regulator is bad too!?!?
- caffcruiser
14 May 2006 11:22
Checked my rectifier. Both diodes on the center terminals (yellow 2) are shot. Pulled it out to get a better look and it's fried.
So I need a new rectifier.
Now, here's my question tho... what are the chances that the regulator is bad, or will go because of stress that may have been put on the charge system?
I found a custom build reg/rec unit online that has both in one plate, so if I can I'd just use that.
Would it be a waste over buying just the rec?
- RetroRiceRocketRider
Re: Bad rectifier... whats the chances the regulator is bad too!?!?
14 May 2006 11:34
Welcome to KZr caffcruiser.
Not knowing what year and model KZ you have, it's going to be a little difficult to tell you exactely what will and won't work for sure.
I'm thinking it's a '77 KZ650?
Regardless of that info, if you have access to a multimeter to test the regulator, that would be my first suggestion.
Also be sure to check the wiring and connectors for damage and/or wear.
Being that most of our KZ's are roughly 20 years old or older, there will be parts like wiring that just degrade over time and will need to be repaired/replaced.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- kawsakiman
14 May 2006 11:57
where did you find the replacement? i'm also looking for one for a 77 kz650.
- caffcruiser
14 May 2006 15:22
RetroRiceRocketRider wrote:
Yes, the bike is a 77. I believe after that they went to a completely different electrical setup?
Anyhow, the replacement is from oregonmotorcycleparts.com.
Thats the combo unit. He also sells a rectifier unit seperately.
Can you check the regulator if the rectifier is shot? I know almost nothing about electrical systems, so I'm sorry if these questions are dumb. haha
How do I check the regulator?
Post edited by: caffcruiser, at: 2006/05/14 18:24
