headlight is dim
  • pimpstic
  • pimpstic's Avatar Topic Author
headlight is dim
15 Aug 2011 19:15
#469233
does this mean the bulb is bad?
78 KZ1000 LTD
YOUR NOT RIDE'N UNLESS YOUR KZ RIDE'N
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
Re: headlight is dim
15 Aug 2011 19:20
#469235
Depends upon many variables. Was your bike running? If so, was it idling or mid-high RPMs? What kind of headlight do you have? What's the wattage? Etc.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • pimpstic
15 Aug 2011 19:27
#469240
I dont know too much about the wattage.....the bike is running and has a brand new battery......I am assuming I have the stock headlight.....sorry I dont know too much about what I have :(
78 KZ1000 LTD
  • otakar
  • otakar's Avatar
15 Aug 2011 20:02 - 15 Aug 2011 20:03
#469245
You will have to look into your factory service manual and see if you have a "reserve lighting device" on your bike. If so, it will run your Hi-Beam at half voltage if your Lo-Beam burns out. your owners manual may have that info also.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 15 Aug 2011 20:03 by otakar.
  • pimpstic
15 Aug 2011 20:03
#469246
ok I will do that, thanks!
78 KZ1000 LTD
  • MFolks
  • MFolks's Avatar
15 Aug 2011 23:34
#469286
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
I'd drop the headlight(remove it) and check the voltage at the three prong socket the plugs into the headlight(at the top of the list).
