Turn Signals will not blink of flash.
- jms3257
Re: Turn Signals will not blink of flash.
10 Aug 2011 15:30
When replacing the flasher unit, check to see it isn’t a heavy duty one, cars and trucks that have several bulbs in the system or if you pull a trailer a HD one is required to handle the extra bulbs, can make a standard system blink slowly. Also as suggest check for bad ground wires between the turn signal units and the frame.
Jim
Jim
1980 KZ1000 LTD
Been away from riding for way too long, enjoying the journey back.
Last edit: 22 Jan 2013 03:19 by martin_csr.
- fuvny
26 Aug 2011 06:05bountyhunter wrote:bad flasher unit.79kz650owner wrote: I just turned on the Hazard lights, all the light turn on and stay on but they will not flash.
If somebody changed to LED bulbs, they won't work with thermal flasher units. You need a solid state flasher.
If you want to Change your led bulbs,which is easy as normal bulbs, you just need find right size bubls. i have ever bought from these wholesales, like BangGood , DX etc, they selling very cheap, I just update my old headlight with led last month, It works like champion. so you can check this site,hope it can help you.
