Another coil question.
- loudhvx
Re: Another coil question.
02 Aug 2011 18:42otakar wrote: I know that the 2.2 Ohm coils will not work on the KZ1300. It uses the same picups as the other bikes but three of them. They heat up quite a bit and crack on the 1300. I suppose one can try the 2.2 ohm coils and see what happens.![]()
Yeah, I've always been puzzled by that. I wish I could get some test time on a 1300 to see what's happening with the dwell... just for my own curiosity.
What is the redline on one of those?
It would be nice to be able to get the 1300 to be able to run the same parts as the i-4's.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- otakar
02 Aug 2011 18:52
The Red Line is 8K on the 1300 but I have had it to 9.5k a few times.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- 0Z.Z1R Mk2
03 Aug 2011 00:31
So,in conclusion...
Are you saying that I cant run green 3 ohm dyna's with my stock ignition?
Heres a pic of the the igniter.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- otakar
03 Aug 2011 02:06
Yes you can. The question is, will it give you the optimum spark? If anyone here has run this stile igniter with the gray 2.2 Ohm coils with total success than the gray coils would be a much better choice.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
03 Aug 2011 02:20The external resistor takes a lot of the heat out of the coils and improves their lifetime. It also reduces the voltage across the coil which decreases spark energy. No free lunch in electronics.....Patton wrote: Z1E listing for Dyna green 3 ohm coil says,
...For some Kawasaki bikes with a resistor in the circuit (KZ1000 79 & 80), the 3 ohm coil is the best choice - just remove the ballast resistor from the circuit....
Wonder why Kawasaki didn't simply fit the higher resistance coils in the first place instead of using lower resistance coils that required a resistor?
The following user(s) said Thank You: Patton
- bountyhunter
03 Aug 2011 02:21You need to run whatever coil impedance came stock which the igniter is designed to work with.0Z.Z1R Mk2 wrote: So,in conclusion...
- 0Z.Z1R Mk2
03 Aug 2011 08:17bountyhunter wrote:You need to run whatever coil impedance came stock which the igniter is designed to work with.0Z.Z1R Mk2 wrote: So,in conclusion...
Thanks to all.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- otakar
03 Aug 2011 10:14 - 03 Aug 2011 10:15
The MK II system had some shortcomings, this is why I suggest installing a "J" series igniter and going with the 2.2 ohm coils. This is an inexpensive and good update. To go with a Dyna-S would actually be a step backwards.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 03 Aug 2011 10:15 by otakar.
- 0Z.Z1R Mk2
03 Aug 2011 19:09
Thanks otakar,I already have a set of green coils,was hoping to use these on the bike.
Never mind,will flog these off and get the 2.2 ohm coils instead.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- loudhvx
04 Aug 2011 14:160Z.Z1R Mk2 wrote: Thanks otakar,I already have a set of green coils,was hoping to use these on the bike.
I think Otakar and I would agree that if you already have the green coils, you should try them.
We are only saying that the gray coils may be better suited, but there is also a very good chance the green coils will work fine, and since you already have them...
I run 3 ohm Accel coils with the ignition designed for 2.3 ohm coils. It works fine, and I can't tell a difference between them and the factory coils when running normally. However, the only time I've had any trouble was when the plug gap was openened up to double the normal gap. Then the spark would fail to arc when the throttle was wide open. I put in new plugs with normal gap and the bike ran fine again.
As a side note, I can confirm for Otto, from the above, that the plugs being opened up to a much larger gap did make the bike seem more lively. (The tradeoff being that it stresses out the coil and igniter.)
So there is a good chance that you can run the green coils and never miss anything, unless you are doing other things to get more power (larger plug gap or higher compression or really high RPMs).
1981 KZ550 D1 gpz.
Other links.
Other links.
- otakar
04 Aug 2011 16:03loudhvx wrote:0Z.Z1R Mk2 wrote: Thanks otakar,I already have a set of green coils,was hoping to use these on the bike.
+1
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- 0Z.Z1R Mk2
05 Aug 2011 00:13
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
