bad coil? whats next?
- newowner79kz750b1
- 79 kz750b4
- Lucid
- Thank you received: 1
78 KZ650B Cafe
- Topper
- Thank you received: 133
Also test the resistance on your spark plug wire caps. Remove the cap from the end of the plug wire, set your multi-meter up to measure ohms and put one probe inside the cap (where the spark plug was) and the other probe where the plug wire used to be, you should get about 5k ohms resistance. If not you've got a bad plug cap. I guess you could also just swap the caps around like I suggested for the plug, but it's easy enough to measure the resistance.
If neither the plug itself or the plug cap is the problem then I'd test your coils.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- newowner79kz750b1
- 79 kz750b4
- Topper
I've heard of kits that let you cut the wires close to the coil (leaving a little nub) and then attach new wires. So long as you don't have a short in that nub, seems like it could work.
Given your description, I don't think you're having a coil problem. I suspect either the plug, plug cap or wire (but I'm still a noob myself, so what do I know?)
I know you tested by pulling the wire off one plug, but have you visually checked for spark?
Here's how I'd approach this:
Visibly verify spark (or lack thereof) on both plugs. Assuming spark on left cylinder and not the right, swap the plugs and test again. If you now have spark on the right and not the left, you've got a bad plug. Replace both.
If nothing changes when you swap the plugs, do the same thing with the plug wire end caps.
If there's still no change, get out your multimeter and test the coils for resistance and voltage (the procedure is the manual).
1979 KZ750 Twin
- newowner79kz750b1
- 79 kz750b4
also one more thing. say it is just the cap. i cant find the caps online any where! on the resistor kinda which isnt good! so then what?
- MFolks
- Thank you received: 540
Ignition Systems Testers
www.lislecorp.com/divisions/products/?pr...ivision=1&category=8
Try here for sparkplug caps:
www.z1enterprises.com/searchresult.aspx?All=True&KeyWords=ngk
- MFolks
Dyna and others provide either a copper sparkplug wire(leads)or supression wires to reduce the noise. If you go this route, do not run sparkplugs with an "R" in the number like B8RES as this is a resistor sparkplug, so combined with supression sparkplug wires/leads, you may have reduced sparkplug energy.
- newowner79kz750b1
- 79 kz750b4
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Topper wrote: ...(but I'm still a noob myself, so what do I know?)
Yeah! What do you know?!?!
Eeerrr... listen to him - good info! :laugh: :laugh: :laugh:
Peace and good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
The Dyna and Accel sparkplug wires/leads are designed to fit over the "Nut" when it's tightened down on the sparkplug. These do not have any resistors for electrical noise reduction/supression like what came with the bike.
If you luck out and find your ignition coils have replaceable sparkplug wires,the 7mm ones from the local hot rod/speedshop should fit. All you have to do is cut them to the right length as the sparkplug end is molded on the wire/lead.
- newowner79kz750b1
- 79 kz750b4
