bad coil? whats next?
- newowner79kz750b1
- 79 kz750b4
Re: bad coil? whats next?
01 Aug 2011 16:54 - 01 Aug 2011 16:57
i have points. i think i have non resistor wires on right now because i had to unscrew the metal caps off the spark plugs to get my spark plug wire caps to fit over the plug
Last edit: 01 Aug 2011 16:57 by newowner79kz750b1.
- Topper
01 Aug 2011 16:56
I think he stated previously that he's got points.
Assuming a stock coil and wires, you'll want resistor plug caps.
Go to your local motorcycle shop parts counter and ask what they have there. They don't need to be specific to your bike. You just need right angle 5k ohm resistor plug caps. Take one off the bike into the parts counter with you.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- newowner79kz750b1
- 79 kz750b4
01 Aug 2011 17:05 - 01 Aug 2011 17:06Topper wrote: I think he stated previously that he's got points.
. i think i have non resistor wires on right now because i had to unscrew the metal caps off the spark plugs to get my spark plug wire caps to fit over the plug?
also if its a bad coil i was going to get the emgo coil, but i will need the caps also, but it doesnt say if it will need resistor or non resistor caps
Last edit: 01 Aug 2011 17:06 by newowner79kz750b1.
- otakar
01 Aug 2011 17:09
Sorry I did not want to read threw the whole post. If you don't want to run resistor caps at all you don't have to and just mount standard silicone automotive caps on the wires. You will have a bit better spark without resistor caps. I don't think you will be using an AM radio on the bike to notice any interference to require resistor caps. I do not run any Resistance on my bike at all.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- newowner79kz750b1
- 79 kz750b4
01 Aug 2011 17:18
ok great! thank u guys so much for all your help!. this is my first bike and first year riding and all im trying to do it get my bike ridable so i can enjoy it the rest of the summer
- clutch
- I wish I had a tad more patience to do it better!
02 Aug 2011 02:41otakar wrote: If you don't want to run resistor caps at all you don't have to and just mount standard silicone automotive caps on the wires. You will have a bit better spark without resistor caps.
Thank you! This answered a question I had on a different thread
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- Topper
02 Aug 2011 09:51
At the risk of hijacking this thread...
Is it just AM Radio that this will cause interference with? My (very limited) understanding is that running without any resistance creates a bunch of electromagnetic interference.
Could that interfere with things like CB radios, cordless phones, cell phones, wi-fi, etc?
And how far away would the effect reach?
1979 KZ750 Twin
1979 KZ750 Twin
- otakar
02 Aug 2011 10:20
This would reach just if you are right next to it. I use a GPS and a video camera on the bike and the camera is about 6" away from the #4 plug. There is no interference that I have noticed at all. Yes it would interfere with a CB unit that is within about 6 feet of it. It will not interfere with the modern stuff.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
02 Aug 2011 12:59 - 02 Aug 2011 13:01
Yes, it depends on how well shielded the electronic gadgets are.
The time I notice the most problems with the interference is when using sensitive, digital multimeters (Flukes and cheap chinese ones both). If I recall, one meter was going crazy without even touching the bike. I actually had to go and get an analog meter in order to work on some of my buddies bikes.
It's not a big deal to go without resistor plug wires. You can always throw in resistor plugs in a pinch if you encounter a problem with RF interference.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 02 Aug 2011 13:01 by loudhvx.
