under the contact breaker
  • loudhvx
  • loudhvx's Avatar
Re: under the contact breaker
15 Jul 2011 12:52
#462993
cpreset wrote: so i am going to replace the whole ignition system so what do i need to get to replace it
Why? How do you know it's bad?
To replace it, you need coil, wires, igniter, pickup, rotor/advancer.
But I doubt all of the above are bad, and the factory ignition is pretty good, compared to the Boyers or Dyna S.
You can even make a replacement igniter for about $25 if you stick with the factory ignition.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
  • cpreset
  • cpreset's Avatar Topic Author
15 Jul 2011 18:47
#463046
im going to replace all but the coil because i know my cables are bad so if im going to replace a part might as well update the 30yo system
  • loudhvx
  • loudhvx's Avatar
16 Jul 2011 01:07 - 16 Jul 2011 01:09
#463099
Ok, but just so you know, the coil is really the only part that needs to be replaced after 30 years. The rest of system has very few failures. Not that they don't go bad, but the coil is far far more likely to be bad than the rest of the system.
Definitely don't toss it. Someone somewhere will want it to upgrade their 400 or 750 twin.
Last edit: 16 Jul 2011 01:09 by loudhvx.
  • cpreset
16 Jul 2011 03:38
#463123
Thanks for the tips that will save me some money
