under the contact breaker
- cpreset
- Thank you received: 2098
cpreset wrote: hey my bike is a 81' kz440 ltd and in all the diagrams the stuff under the contact breaker looks totally different then what i got so help me if you can what do i got?
That's what i got much help please
Appears to be a stock Kawasaki electronic ignition, that works in conjunction with an I.C. Igniter box.
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
- cpreset
- cpreset
- steell
cpreset wrote: you wouldn't happen to know what the gap should be between the two things at their closest point
Why? There is no adjustment.
I use those same parts to convert 750 twins to electronic ignition.
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- cpreset
- MFolks
- Thank you received: 540
On some of the older bikes, this part is becomming heat sesitive and will quit working possibly stranding you until it cools off.
Here's test procedure I wrote for the bigger 4's having the same "Pulsing coil"
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
- cpreset
- cpreset
- MFolks
- cpreset
