modifying a mechanical advancer
- Godfrey
09 Jul 2011 07:47
My cams have so much duration that I found I could add 5 degrees initial timing to the stock 10 degrees, called for by kawasaki with no issues. I would however still like to limit total timing to 38-4o degrees, and have to take 5 degrees out of the mechanical advancer. Just curious if any of you have done this same thing, and how you modified the mechanical advancer to achieve it?
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
- mark1122
- Keep twisting it
Re: modifying a mechanical advancer
09 Jul 2011 08:22 - 09 Jul 2011 08:25
i have heard that some guys change the spring, but that seems like a tedious trial and error type of job.
i wonder if the Z1/kz 1000 advancer would Fit/work. they came in 10, 15, and 20 degrees of initial advance.
the Dyna 2000 is an electronic programmable advancer. it eliminates the stock mechanical advancer.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 09 Jul 2011 08:25 by mark1122.
09 Jul 2011 08:36
Could possibly bend the two "advanced stops" inward to reduce outward motion of the two weight arms, or fashion blocks of some sort between the stops and arms, but either of these methods seems very crude and inexact, especially when compared to installing the electronic programmable advancer as suggested by mark1122.
09 Jul 2011 08:41Godfrey wrote: My cams have so much duration that I found I could add 5 degrees initial timing to the stock 10 degrees, called for by kawasaki with no issues. I would however still like to limit total timing to 38-4o degrees, and have to take 5 degrees out of the mechanical advancer. Just curious if any of you have done this same thing, and how you modified the mechanical advancer to achieve it?
Including information about bike year and model may elicit better responses.
And it's easy to put the information in your signature where it will automatically appear in posted messages.
When done, the signature information appears in all posts, past and future.
And may be changed as often as desired.
Attachment addsig.jpg not found
- Godfrey
09 Jul 2011 14:55
The engine is a 1980 KZ750E
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
- bountyhunter
09 Jul 2011 18:11 - 09 Jul 2011 18:12
You could build up a silver solder "pad" on the stop notches which would let you adjust it by filing that pad down. You need to adjust how far out the two metal "wings" can open at full advance. Messing with the springs won't help, that just changes the rate they open versus RPM.
Last edit: 09 Jul 2011 18:12 by bountyhunter.
- mark1122
- Keep twisting it
09 Jul 2011 18:16bountyhunter wrote: You could build up a silver solder "pad" on the stop notches which would let you adjust it by filing that pad down. You need to adjust how far out the two metal "wings" can open at full advance. Messing with the springs won't help, that just changes the rate they open versus RPM.
good point. and as u add wieght with solder, it will slightly alter the rate of advance (will adv. faster or sooner.).
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Godfrey
10 Jul 2011 15:04
glad I got extra parts, tryed bending the advance stops in and have a small fracture in the metal, I may fill them with solder, and good idea with the silver solder , could fine tune with some trial and error.
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
- Motor Head
10 Jul 2011 18:08
Bent and fractured? How far before that happened? I've only gone enough to get rid of about 4 degrees total advance. A small build up of material at the stop should not effect advance rate just total. Adding to the moving arm/ weight would increase advance at lower RPM, same as a weaker spring. The programmable would be a great choice for those with the bucks. But how many settings are there or can you set it as wanted? Some would only have like 4 different curves pre-programed to choose from.
Doing it mechanically is the old fashioned way, more time consuming, but cheaper if you have the time. We know you have the patience.
- mark1122
- Keep twisting it
10 Jul 2011 18:12Motor Head wrote: Bent and fractured? How far before that happened? I've only gone enough to get rid of about 4 degrees total advance. A small build up of material at the stop should not effect advance rate just total. Adding to the moving arm/ weight would increase advance at lower RPM, same as a weaker spring. The programmable would be a great choice for those with the bucks. But how many settings are there or can you set it as wanted? Some would only have like 4 different curves pre-programed to choose from.
the Dyna 2000 only has 2 curves. 1 for stock, and 1 for a little more lively motor, but u can make your own map if u like to experiment.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- elfmagic17
10 Jul 2011 22:35Patton wrote: Could possibly bend the two "advanced stops" inward to reduce outward motion of the two weight arms, or fashion blocks of some sort between the stops and arms, but either of these methods seems very crude and inexact, especially when compared to installing the electronic programmable advancer as suggested by mark1122.
Would it be possible to drill and tap for a small screw in the advance stop? Juat an Idea.
Kenny Hicks
74 Honda CB550
74 Honda CB550
- Godfrey
11 Jul 2011 22:00
Ya know Patton I thought of the screw idea, not sure i trust locktight spinning that fast, plus I wonder if there would be a balance issue.
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
