Testing Coil and Pickup..
- xicano73
23 Jun 2011 22:48
Hello Forum!!
Can Someone clue me in on how to test a coil and pickup on a 1981 KZ440?
Having some starting issues and no spark when issue presents no spark at plug.
THANKS SOO MUCH IN ADVANCE!
p.s. Jus purchased best meter I could get at Lowes....if anything else is needed please advise. I also have a an extra coil off a four cylinder KZ..not sure if they are interchangeable.
Thanks again!
Thanks again!
Hardtail KZ440....No front brake or fenders, springer seat! Insanity on two wheels!
- MFolks
Re: Testing Coil and Pickup..
24 Jun 2011 01:18
I wrote this for the bigger 4's, but imagine the readings will work for your bike:
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
- bountyhunter
24 Jun 2011 15:22
The typical failure modes that a coil will have can't be tested by a static (Ohm) test. My manual shows them using some kind of high voltage tester which might work, but ohming them out only tells you if they have an open or short.
