dyna coils greenies 3ohms kawasaki kz 1000 ltd
- Harleykiller
10 Jun 2011 23:34
Hi! I put the 3ohm coils on my 82 kz and the kit also came with the stator plate. Do I need to install that to or can I keep the stock plate on it.
- otakar
Re: dyna coils greenies 3ohms kawasaki kz 1000 ltd
10 Jun 2011 23:44 - 10 Jun 2011 23:46
Wrong coils for that year bike. The green coils are intended for either points or the dyna electronic ignition. The Kawasaki electronic ignition is 2.2 Ohm and requires the Gray coils. The green coils will work but will give a 30% weaker spark. I am not quite sure what you mean when you say "stator plate"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 Jun 2011 23:46 by otakar.
- MFolks
11 Jun 2011 00:22
Funny, I've checked the ohm's on the old ignition coils that came with my 1982 GPz1100 B2(both sets as I bought spares when I bought the bike) and all 4 check at 3 ohm. Maybe the FI has a different dwell requirement?
- otakar
11 Jun 2011 00:36 - 11 Jun 2011 00:38
Coils for those bikes should read between 1.8-2.8 Ohms. In the early Kaw IC ignitions, the only exception to the 2.2 Ohm rule is the KZ1300/ZN1300. They are 3 Ohm. The EFI GPZ bikes were no different even though they had electronic advance. As the coils get older the resistance goes up in them. I had some 1300 coils that measured as much as 7 Ohms.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 11 Jun 2011 00:38 by otakar.
- MFolks
11 Jun 2011 00:40
Another question, My 82 still has the mechanical advance, I think the 83's went to the electronic advancers..
- otakar
11 Jun 2011 00:48 - 11 Jun 2011 00:51
No eBay APP ID and/or Cert ID defined in Kunena configurationYes that is correct. The ECU units are however retro active but not the other way around. Thank god you do not have the 81, they were terrible. from 82 on they worked quite well. I think the 82 was the best balance of injection with simplicity. But they should ALL have 2.2 Ohm coils. from Dyna they are Gray.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 11 Jun 2011 00:51 by otakar.
- otakar
11 Jun 2011 00:56 - 11 Jun 2011 00:57Attachment fd6b337b1f1a186fd5bc9831f5aae55a.jpg not found
Here is the application on my bike with the stock Kawasaki IC ignition.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 11 Jun 2011 00:57 by otakar.
- MFolks
11 Jun 2011 00:59
I've got the green 3 ohms on now but I'll consider going to the 2.2 ohm ones in the future. I have not fired it up yet as I'm doing some wiring upgrades and changing some of the open backed connectors to the Weather Pack style used in the newer cars.
- otakar
11 Jun 2011 01:05
As I mentioned, the 3 Ohm will work but it is a poor spark. I have my gap open to .060 on my plugs you will have to be at about .020 with the green coils. Once I install my MSD MC-2 Ignition I am going to .7 OHM coils and a .080 gap.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
11 Jun 2011 01:10
Another thing I did is to make up two shorter cables going to the ignition coils using Weather Pack connectors. The stock ignition coils had 1/4" wide male push on terminations, but the Dyna coils have screw terminations.The Dyna coils come with 10-32 X 5/16" screws in the kit, so don't loose them as replacement screws may be too long and will bottom out before being tight.
With the shorter cables, I can now easily remove the coils when doing valve adjustment rather than wearing out the screw terminations on the coils. I Just release the connector lock, and pull the connectors apart. I reversed one male/female conector pair so it's almost impossible to connect the ignition coils up wrong.
- Harleykiller
11 Jun 2011 08:18
Thanks for the replies and information and ebay site. Thanks for helping out a Navy corpsman.
- otakar
11 Jun 2011 08:41
Post an appropriated Avatar. I once made the same mistake about the coils when I first got into the "J" bikes I wondered why my bike got such poor gas millage and why it started missing at 6500+ revs. Than I figured it out and solved all problems.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
